Lenovo Ideapad 5 15ITL05 Bios File
  • Jk KIM
    • Feb 2023
    • 6
    • S.korea
    After Bios updated my laptop bricked ;(
    Lenovo Ideapad 5 15ITL05,intel i5 , WINBOND W25Q64xV
    I need Bios(.bin) file
    all I have is a '.fd file' but I can write this using CH354A
    Also in CH341A programmer, I can find 3 memory name (W25Q64BV, W25Q64CV, W25Q64FV). Why is this 3 and which one should I write??
    Thank u for reading long writes.
    Masters..... PLZ, help me.
  • peste
    • Dec 2016
    • 13412
    • ROMANIA
    Re: Lenovo Ideapad 5 15ITL05 Bios File
    the one you find on the bios chip.. first post the original bios of the laptop here..
    • Jk KIM
      • Feb 2023
      • 6
      • S.korea
      Thank u for your reply,
      Is there any other model's bin file which can use....?
      • peste
        • Dec 2016
        • 13412
        • ROMANIA
        post the bios first so we can see it and someone will help you with a bios ok..
        • Jk KIM
          • Feb 2023
          • 6
          • S.korea
          This file is my first backupfile before I do ROM Writing..
          Thank u
          • hardware1
            • Sep 2021
            • 2946
            • N/A
            Thank u
            Your file size should be 8MB not 1MB!
            Write your Device Serial Number.
            all donations are welcome,
            • Jk KIM
              • Feb 2023
              • 6
              • S.korea
              Model name is IdeaPad5 15ITL05
              S/N is PF2JN1EE
              • hardware1
                • Sep 2021
                • 2946
                • N/A
                S/N is PF2JN1EE
                According to your Serial Number, your device should contains 2 Bios Chips (8MB +16MB).
                I will attach a Virgin Bios from Lenovo, but you need to backup your Chips before program them.
                Note: this Bios doesn't contain your DMI data.
                • zientas77
                  • May 2022
                  • polska
                  It works! Thank You very much!
                  • hardware1
                    • Sep 2021
                    • 2946
                    • N/A
                    You're welcome.
                    • laptecperu
                      • May 2023
                      • 5
                      • PerĂº
                      Hi friends, could you help me? I have the same IdeaPad 5 laptop. I downloaded the file that contains two bin files, but I don't know which ones are the BIOS. On my mainboard, I see three BIOSes, but I don't know which two need to be read and written. Please help. Thanks in advance.
                      • peste
                        • Dec 2016
                        • 13412
                        • ROMANIA
                        post S/N, full name and model, motherboard model, TYPE,etc.
                        post the contents of the bios chip even if it is corrupted..
                        • laptecperu
                          • May 2023
                          • 5
                          • PerĂº
                          Please, I need a rebuild BIOS for an
                          Lenovo Ideapad 5-15ITL05 Laptop - Type 82FG
                          Mainboard: GS55JGS55K NM-D211 REV 1.0
                          serial: PF3MKDXN
                          The laptop turns on, there's no video, just the power LED. It turns on for a while, turns off, and then goes into that loop. I found three BIOS CHIP
                          1 8MB UB2
                          1 64MB UC703/UC704
                          1 128MB UC702
                          I don't know if I should flash them one by one or if I need a clean, modified BIOS with my region's settings. I downloaded a BIOS directly from Lenovo, but it's almost 27MB, but it comes in a single file. I hope you can help me. Thank you.
                          • peste
                            • Dec 2016
                            • 13412
                            • ROMANIA
                            serial: PF3MKDXN
                            1 8MB UB2
                            1 64MB UC703/UC704
                            1 128MB UC702
                            bios extracted from Lenovo site update for ideapad 5-15ITL05
                            DMI 42E000 - 42FFFF in 16MB bios​
                            • laptecperu
                              • May 2023
                              • 5
                              • PerĂº
                              thankyou very mucho, but no work Hi friend, I have already flashed both BIOS, but it remains the same, the power LED lights up, stays on for a few seconds, turns off and turns back on,,, I flashed it with a BIOS programmer and tweezers to read the chip without unsoldering,,, do you think it is better to program it by unsoldering the BIOS chip and then re-soldering it?
                              • peste
                                • Dec 2016
                                • 13412
                                • ROMANIA
                                The bios chip must be unsoldered from the board before writing or reading..
                                do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                solder wires between the programmer and the bios chip..
                                you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHow​
                                • laptecperu
                                  • May 2023
                                  • 5
                                  • PerĂº
                                  Ok friend, I understand, I have this socket from my programmer, with that I can program the unsoldered BIOS chip, I upload a photo of my socket
                                  • peste
                                    • Dec 2016
                                    • 13412
                                    • ROMANIA
                                    ok...ok take the chip out of the board put it in the adapter and the adapter in the programmer...
                                    • laptecperu
                                      • May 2023
                                      • 5
                                      • PerĂº
                                      Hello friend, good day, I unsoldered and flashed the 2 BIOS, but the laptop still doesn't turn on, only the power LED, the small BIOS UB2, is it also necessary to flash it?
                                      • peste
                                        • Dec 2016
                                        • 13412
                                        • ROMANIA
                                        either you didn't write them correctly or the laptop has another problem...
                                          Lenovo IdeaPad IdeaPad 5 15ITL05 Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 5 15ITL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 5 15ITL05 boardview and IdeaPad 5 15ITL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                        • pcwhiz24
                                          Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                          by pcwhiz24
                                          Model: Lenovo IdeaPad 3 14ADA05 81W0
                                          S/N: PF2BZS7D
                                          I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                          I already have a CH341A programmer...
                                          04-07-2025, 07:10 PM
                                        • Jk KIM
                                          Lenovo Ideapad 5 15ITL05 Bios File extract
                                          by Jk KIM
                                          Hi
                                          I need to extract bin file from bios update file which downloaded at Lenovo web site.
                                          Pls extract bin file from exe file...
                                          I attached exe file!
                                          Thx!...
                                          02-03-2023, 07:40 AM
                                        • carabas20
                                          BIOS bin file for Lenovo Ideapad 3 17ADA6 + 3 15ADA6
                                          by carabas20
                                          Hello i need BIOS bin file for Lenovo Ideapad 3 17ADA6 S/N PF3AALFM.
                                          I have updated my bios from the official website , and after the laptop restarts it went to black screen and now i can not do anything. I have been trying to flash the bios with CH341A but from the office website i can see only the CAP file. I have need trying to modify the cap file following the guides and video from the forum but no luck.
                                          If anyone has a dump of original bios for this model will be great or clean the faulty bios for me , i have attached my backup bios...
                                          06-01-2023, 01:19 PM
