Looking for BIOS ASUS R900VM-LA-8223P
  • DaJetzi
    • Aug 2025
    • Deutschland
    Hello, I'm looking for a working BIOS after an update crashed and my laptop stopped working. It's possible that the wrong update was used.
    I was able to read the contents of the EEPROM afterward.
    From what I've read online, it should be possible to create a functional BIOS file from the old contents in combination with an update file.
    However, that's beyond my capabilities.
    I would be very grateful if anyone could help me with this task.
    Thanks in advance.
    Model: R900VM
    MB Ver: K95VM
    QLC90 LA-8223P
    Rev: 1.0
    2012-01-19
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • davidebeatrici
    Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
    by davidebeatrici
    I had 3 people contact me in a week because Windows suddenly didn't boot:
    As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
    The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
    Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
    06-17-2025, 12:59 PM
  • jinki_dadou
    ASUS ExpertCenter D700MD need update bios
    by jinki_dadou
    helle
    in have asus desktop
    model : D700MD-5124000950
    CPU i5 12400
    I wanted to upgrade the processor i7 13700
    when I change the processor show black screen and fan spinning fast
    i ask asus technical support
    the answer : include microcode in the latest update bios
    he give me file 1 update bios
    2 microcode
    2 fils in tha attachments please help me
    ( sorry for my dab english )...
    05-18-2025, 02:20 AM
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
