Lenovo Thinkbook 14-IIL
  • Blaszow
    • Apr 2025
    • 10
    • Polska
    Hello everyone. I have problem most likely with bios because I found no shorts on motherboard, all voltages seem to be present, laptop keeps restarting, the fan spins for a while a then stops when it starts spining again the keyboard lights up and it happens over and over. I tried bioses from other topics and they didn't work.
    I tried to clean ME myself in my original bios but for some reason after cleaning ME, ME analyzer showed that bios is corrupted, still new to editing bios so I appreciate any help or advices.
    Name and model: Lenovo Thinkbook 14-IIL 20SL
    Serial number: LR0EHZVK
    Motherboard: DALVACMB8D0 REV D
  • Stefan Steff
    • Mar 2024
    • 368
    Try first this bios file , rebuild from your original dump.
    If it's not working then try the second file which has a clean ME region.
    Please provide feedback.
    • Blaszow
      • Apr 2025
      • 10
      • Polska
      Didn't work
      • Stefan Steff
        • Mar 2024
        • 368
        Didn't work
        Don't give up yet...
        This file is my last try to help you, if it's not working either then wait for somebody else to help you out.
        • Blaszow
          • Apr 2025
          • 10
          • Polska
          I'm not giving up so easily, thank you tor helping me, I will try your bios with clean ME and then I'm going to try your last bios, of coruse I will let you know if any of them worked.
          • Blaszow
            • Apr 2025
            • 10
            • Polska
            Unfortunately none of these bioses worked, thank you for the help though, with the last bios you shared laptop switched on but no restarts at all, just in case I hooked up an hdmi cable but nothing happend, maybe it's time to pull out he board and make deeper investigation.
            • Stefan Steff
              • Mar 2024
              • 368
              Good Luck!
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • HotSaladMan
                Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                by HotSaladMan
                *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                Model : Lenovo ThinkBook 14S Yoga ITL
                S/N : MP28JT19
                MFG Date : 2022/02/09
                Factory ID PRC4
                MO : MPNXB26080FX
                MTM : 20WE001US
                MODULE FCC ID : PD9AX201NG
                IC : 1000M-AX201NG
                BOARD INFO
                FLV34 LA-KO51P
                REV : 1B 2020-08-24
                Bit of Info
                Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                chip id, so i would always uncheck the id check, so it would bypass the error
                i did in fact make...
                11-07-2024, 07:46 AM
              • TecnicaNTT
                Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                by TecnicaNTT
                I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                I am now asking here for help if anyone knows how to do this in...
                09-20-2024, 08:10 AM
              • mximiliandz
                help bios lenovo ideapad s145-14iil type 81w6
                by mximiliandz
                Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                06-20-2025, 06:50 AM
