NEED BIOS FOR hp 15-dw3085nk (6U7X) Motherboard GPT52 LA-K201P Rev:3.0
  • kamel
    • May 2011
    • 129
    • TUNISIA
    Good evening,
    Bios was corrupted after an update trial by customer. Laptop displays indicating failing Auto-recovery , recovery files not find. Attached Backup.
    s/n : #CND23616YK
    Thanks.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    HP Laptop 15-dw3085nk (6U7X9EA)
    S/n : CND23616YK
    BID : 0899F
    • kamel
      • May 2011
      • 129
      • TUNISIA
      S/n : CND23616YK
      BID : 0899F
      Thanks, I"ll try and revert.
      • kamel
        • May 2011
        • 129
        • TUNISIA
        Hello, sorry for the late feed back. I flashed HP Laptop 15-dw3085nk_0899F.rar dump, it worked ok ,but with a Boot Guard error message display. Accessing Bios setup and Boot menu is possible. Laptop boots from usb key, but not from NVME disk. Need first to get rid of Boot Guard error message and see after.
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          What's Boot Guard error message..
          post the dump that you use it now
          • kamel
            • May 2011
            • 129
            • TUNISIA
            Hello, thanks for your reply.
            As I said in post 4, I used HP Laptop 15-dw3085nk_0899F.rar dump, worked out and attached by hoaca388 to post 2.
            Unfortunately, I didn't took note of the error message. The customer, picked up his laptop to work with as it is for some time with a new formated drive.
            Also I must thank hoaca388 for the dump.
            • glovecaps
              Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
              by glovecaps
              I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
              My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
              The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
              11-25-2024, 04:23 PM
            • to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
              by to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
              I have opened the laptop and identified the main BIOS chip...
              10-24-2025, 01:35 AM
            • oragano
              ASUS ex-b250-V7 motherboard bios corrupted - by me
              by oragano
              hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
              So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
              i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
              10-17-2024, 02:53 AM
            • AkaBukai
              Is it okay to flash stock bios onto the motherboard's BIOS?
              by AkaBukai
              Hi there,
              I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
              The little LED on the power button is flashing slowly and nothing happen.
              This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
              So I decided to flash the BIOS using a cheap programmer.
              And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
              I also...
              12-19-2024, 12:15 PM
            • GardevoirForEver
              Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
              by GardevoirForEver
              I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
              Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
              The motherboard of my ASUS...
              11-15-2025, 04:30 PM
