IdeaPad 1 14ALC7 BIOS help
  • AllTexan2026
    • Jul 2025
    I have an IdeaPad 1 14ALC7 Laptop -
    Type 82R3
    There is an EXE file and I cannot seem to spot the raw bin file anywhere within it. Is there anywhere I can get the raw in file or what is the next step I should take?
    Bios: XM25RU128C
    • 31262
    in the past you could run the file and while it's running you could find it's content in the TEMP folder.
    not sure if thats still the case.
    or you could try extracting the content with peazip or innoextract or other tools
    • peste
      • 13661
      • ROMANIA
      Originally posted by AllTexan2026
      Type 82R3
      Bios: XM25RU128C
      post the contents of the bios chip even if it is corrupted..
      post S/N, motherboard model,etc.
      • freenlnl
        • May 2014
        • 31
        • The netherlands
        I have an IdeaPad 1 14ALC7 Laptop - caps and esc key blinking!!!
        Rebuild please
        original bios attached
        Type 82R3
        SN PF52J0PR
        MTM 82R3009DMH
        • hoaca388
          Badcaps
          • Jan 2022
          • 12354
          Originally posted by freenlnl
          Rebuild please
          Type 82R3
          SN PF52J0PR
          MTM 82R3009DMH
          IdeaPad 1 14ALC7 Laptop - Type 82R3
          • freenlnl
            • May 2014
            • 31
            • The netherlands
            Thanks !! works like a charm
            • sanjiv16
              • Jul 2013
              • 52
              • philippines
              PLEASE NEED HELP PO CLEAN BIOS
              LENOVO JS471/JS73 NM-E541
              BLINKING LIGHTS PROBLEM
              MODEL IDEAPAD 1 14ALC7
              BOARD ID # JS471/JS573 NM-E541
              SERIAL NUMBER PF50LX0F
              HERE IS THE ATTACH ORIG. BIN FILE
              • peste
                • 13661
                • ROMANIA
                you have everything you need at post #7..
                https://www.badcaps.net/forum/troubl...a7#post3307240
                • sanjiv16
                  • Jul 2013
                  • 52
                  • philippines
                  thank you so much.
                  • to5it0
                    by to5it0
                    10-24-2025, 01:35 AM
                  • Fr33man
                    BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                    by Fr33man
                    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                    *Novo button power on
                    *Disconnected internal battery...
                    09-23-2024, 01:16 PM
                  • pcwhiz24
                    Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                    by pcwhiz24
                    Model: Lenovo IdeaPad 3 14ADA05 81W0
                    S/N: PF2BZS7D
                    I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                    I already have a CH341A programmer...
                    04-07-2025, 07:10 PM
                  • carabas20
                    BIOS bin file for Lenovo Ideapad 3 17ADA6 + 3 15ADA6
                    by carabas20
                    Hello i need BIOS bin file for Lenovo Ideapad 3 17ADA6 S/N PF3AALFM.
                    I have updated my bios from the official website , and after the laptop restarts it went to black screen and now i can not do anything. I have been trying to flash the bios with CH341A but from the office website i can see only the CAP file. I have need trying to modify the cap file following the guides and video from the forum but no luck.
                    If anyone has a dump of original bios for this model will be great or clean the faulty bios for me , i have attached my backup bios...
                    06-01-2023, 01:19 PM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
