Gm501gm Bios laptop asus
  • Food1244
    • Jun 2025
    • 8
    • United Kingdom
    I recently enabled secure boot and disabled csm on my laptop in the bios.
    Immediately it stopped working. Black screen (no backlight) , keyboard rgb worked, fan turned on. Battery led would flash 3 times then repeat.
    I got a ch341a reader thinking it's not posting so mightve corrupted the bios.
    The files I have are attached. One of the bios from the Asus website and one of what I got from the laptop chip (backup).
    Please help me use these to make a new bios I can use to get this to work
  • hoaca388
    Badcaps
    • Jan 2022
    • 12403
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    How did you do it ? Download the file and unzip it yourself.
    • Food1244
      • Jun 2025
      • 8
      • United Kingdom
      Asus Zephyrus GM501GM. PN: 60NR00F0 MB2330 (214) GM 501GM 16851523. PT:N0CV1817MB0026643 69N14M12C04(01).
      The zip file contains 2 files. The "backup1.bin" contains the bios dump I obtained using a ch341a reader. The "gm501gm.317" is the update file from the Asus support website for my model.
      I dont know how to get a new bios to flash by using these 2 files.
      Maybe I need to start with a bios that has the csm and secure boot settings reset? Since that's what caused it to stop working. (so a bios that has csm enabled and secure boot disabled)
      Let me know if there's anything else I can give to help!
      • hoaca388
        Badcaps
        • Jan 2022
        • 12403
        Take a picture of the QR code and sticker on the RAM slot.
        • Food1244
          • Jun 2025
          • 8
          • United Kingdom
          Attatched is the ram slot sticker
          • Food1244
            • Jun 2025
            • 8
            • United Kingdom
            These are all the stickers
            • hoaca388
              Badcaps
              • Jan 2022
              • 12403
              ROG Zephyrus M_GM501GM
              • Food1244
                • Jun 2025
                • 8
                • United Kingdom
                This worked!! Thank you!!
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • Bloodhoundje
                  HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                  by Bloodhoundje
                  I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                  I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                  After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                  I have desoldered the bios chip (GigaDevice...
                  03-16-2024, 03:12 PM
                • JoWed
                  Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                  by JoWed
                  Hello Community,
                  I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                  07-01-2025, 09:32 AM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • alphabetty
                  novice user attempting first BIOS write on ASUS laptop
                  by alphabetty
                  Hello first post!
                  Ok so after an (ASUSTek) optional Windows update, my old ASUS E403NA laptop rebooted and froze in the BIOS menu screen and was unresponsive so after about 30 mins I powered off and back on again. Now i just get a power LED and a black screen, I have tried all the basic suggestions and all the suggestions on the ASUS site, spoke to ASUS support who said I will need to pay for an RMA.
                  The laptop is worth €50 so I won't be doing the RMA at god knows what price.
                  So I have seen some videos where people have reprogrammed the BIOS...
                  03-07-2024, 08:31 AM
