Gm501gm Bios laptop asus
  • Food1244
    • Jun 2025
    • 8
    • United Kingdom
    I recently enabled secure boot and disabled csm on my laptop in the bios.
    Immediately it stopped working. Black screen (no backlight) , keyboard rgb worked, fan turned on. Battery led would flash 3 times then repeat.
    I got a ch341a reader thinking it's not posting so mightve corrupted the bios.
    The files I have are attached. One of the bios from the Asus website and one of what I got from the laptop chip (backup).
    Please help me use these to make a new bios I can use to get this to work
  • hoaca388
    Badcaps
    • Jan 2022
    • 11653
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    How did you do it ? Download the file and unzip it yourself.
    • Food1244
      • Jun 2025
      • 8
      • United Kingdom
      Asus Zephyrus GM501GM. PN: 60NR00F0 MB2330 (214) GM 501GM 16851523. PT:N0CV1817MB0026643 69N14M12C04(01).
      The zip file contains 2 files. The "backup1.bin" contains the bios dump I obtained using a ch341a reader. The "gm501gm.317" is the update file from the Asus support website for my model.
      I dont know how to get a new bios to flash by using these 2 files.
      Maybe I need to start with a bios that has the csm and secure boot settings reset? Since that's what caused it to stop working. (so a bios that has csm enabled and secure boot disabled)
      Let me know if there's anything else I can give to help!
      • hoaca388
        Badcaps
        • Jan 2022
        • 11653
        Take a picture of the QR code and sticker on the RAM slot.
        • Food1244
          • Jun 2025
          • 8
          • United Kingdom
          Attatched is the ram slot sticker
          • Food1244
            • Jun 2025
            • 8
            • United Kingdom
            These are all the stickers
            • hoaca388
              Badcaps
              • Jan 2022
              • 11653
              ROG Zephyrus M_GM501GM
              • Food1244
                • Jun 2025
                • 8
                • United Kingdom
                This worked!! Thank you!!
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • Bloodhoundje
                  HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                  by Bloodhoundje
                  I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                  I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                  After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                  I have desoldered the bios chip (GigaDevice...
                  03-16-2024, 03:12 PM
                • JoWed
                  Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                  by JoWed
                  Hello Community,
                  I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                  07-01-2025, 09:32 AM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
