This notebook arrived to me with this symptom described in the title, I already tried to re-record the bios with some files from the website but without success, the symptom changes sometimes starting to turn on and off in seconds but it doesn't work
Hp G9 256 no image 5 long 3 short led capslock bliking
Tags: None
post S/N, full name and model, motherboard model, product number,etc.
post the contents of the bios chip even if it is corrupted..
post the bios here, not on other sites..
Every donation made will go towards server fees and maintenance costs. -
Sorry, Model HP 256 G9 Serial number BRM425C3GH
Not possible upload bios, i have message Upload failed. You are not allowed to upload files with the extension bin.Comment
I achievedAttached Filesif you find these attachements useful please consider making a small donation to the site
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
by lapfixHello friends.
hp 15 -da009nk ...la-g07cp.
got this lap with capslock 5 long 3 short.
Try new dump f.48 still the same.
try another dump f.04 power on..no display..consumption 0.498..no caps lock blinking.
all voltage are présent.
pl301/302= 3 and 5 volt.
pl1001 1.082v.
pla1 1.033v
plz1 vcc core 1.058v
plg1 0v..i think it s the Intel grpahic
plw1 1.373v.
plv 3/plv4 vga core 0.918v
consumption 0.498.
original bios version f.02..
any help!... -
by Tom_xHi,
I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
Now with blinking capslock:
All voltage present on big coils, except +VCCGT (i don't know this need for booting)
I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
DDR4 ram is ok, tested on other laptop
WLAN and SSD removed,... -
by Aziz ajrev-1.0
input short remove then caps lock 5 long 3 short no output how to solve this problem -
by dfearI have a "HP Pavilion x360 - 14-ba104na" in for repair. The caps lock flash 3 long and 5 short.
HP says this error means:
The red light blinks three times, and then five, short white light blinks (3 long red, 5 short white)
This condition indicates that the computer does not detect the processor (CPU).
Does this mean the CPU is dead or is there another cause for this fault? -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM - Loading...
