Hp G9 256 no image 5 long 3 short led capslock bliking
  • rick22deus
    • Nov 2021
    • 6
    • Brazil
    This notebook arrived to me with this symptom described in the title, I already tried to re-record the bios with some files from the website but without success, the symptom changes sometimes starting to turn on and off in seconds but it doesn't work
  • peste
    • Dec 2016
    • 12911
    • ROMANIA
    post S/N, full name and model, motherboard model, product number,etc.
    post the contents of the bios chip even if it is corrupted..
    post the bios here, not on other sites..
    • rick22deus
      • Nov 2021
      • 6
      • Brazil
      Sorry, Model HP 256 G9 Serial number BRM425C3GH
      Not possible upload bios, i have message Upload failed. You are not allowed to upload files with the extension bin.
      • rick22deus
        • Nov 2021
        • 6
        • Brazil
        I achieved
        • rick22deus
          • Nov 2021
          • 6
          • Brazil
          Does anyone ?
          • tuyen821991
            • Oct 2024
            • 44
            • Viet Nam
            Does anyone ?
            try
            • rick22deus
              • Nov 2021
              • 6
              • Brazil
              Thank you very much, I will test it
              • rick22deus
                • Nov 2021
                • 6
                • Brazil
                Originally posted by tuyen821991
                try
                Do not work, now the led turns on and off in 2 seconds
                • lapfix
                  Hp 15 capslock 5 long 3 short pb.
                  by lapfix
                  Hello friends.
                  hp 15 -da009nk ...la-g07cp.
                  got this lap with capslock 5 long 3 short.
                  Try new dump f.48 still the same.
                  try another dump f.04 power on..no display..consumption 0.498..no caps lock blinking.
                  ​​​​all voltage are présent.
                  pl301/302= 3 and 5 volt.
                  pl1001 1.082v.
                  pla1 1.033v
                  plz1 vcc core 1.058v
                  plg1 0v..i think it s the Intel grpahic
                  plw1 1.373v.
                  plv 3/plv4 vga core 0.918v
                  consumption 0.498.
                  original bios version f.02..
                  any help!...
                  02-18-2025, 03:34 AM
                • Tom_x
                  HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
                  by Tom_x
                  I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
                  HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
                  Now with blinking capslock:
                  All voltage present on big coils, except +VCCGT (i don't know this need for booting)
                  I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
                  DDR4 ram is ok, tested on other laptop
                  WLAN and SSD removed,...
                  07-20-2023, 10:10 PM
                • Aziz aj
                  caps lock 5 long 3 short black screen
                  by Aziz aj
                  rev-1.0
                  input short remove then caps lock 5 long 3 short no output how to solve this problem
                  06-08-2024, 07:47 AM
                • dfear
                  HP Pavilion x360 - 14-ba104na - 3 long and 5 short caps lock code.
                  by dfear
                  I have a "HP Pavilion x360 - 14-ba104na" in for repair. The caps lock flash 3 long and 5 short.
                  HP says this error means:
                  The red light blinks three times, and then five, short white light blinks (3 long red, 5 short white)
                  This condition indicates that the computer does not detect the processor (CPU).
                  Does this mean the CPU is dead or is there another cause for this fault?
                  12-10-2022, 06:54 AM
                • Superbee_dad
                  Sharp 80” long short flash backlight error - Help
                  by Superbee_dad
                  Hello Sharp TV experts
                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                  01-24-2025, 11:51 PM
