[REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
  • hyperwood
    • Jun 2025
    • 7
    I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
    The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
    I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
    ✅ What I need:
    • A working 2MB BIOS dump
    • Matching NM-E471 Rev. 2.0, e.g. JY575 / JY576 / JY676 etc.
    • Ideally already tested or extracted from a working system
    Thank you very much for any help or a valid dump! 🙏
    I can also upload my dead dump if needed.
  • hardware1
    • Sep 2021
    • 2936
    • N/A
    Originally posted by hyperwood
    ✅ What I need:
    What is your laptop issue? Why you was trying to flash the BIOS anyway?
    Most likely your 2MB chip is vBIOS (Graphics Card firmware). We need your laptop serial number, the number of the chip on the motherboard (Or an image for it), the exact GPU on the motherboard.
    Also a backup from your 2MB vBIOS chip and your 32MB BIOS chip if you can.
    all donations are welcome,
    • hyperwood
      • Jun 2025
      • 7
      Click image for larger version  Name:	52D1E985-9CF4-4D4D-9ACF-39795CBF8D54.jpg Views:	0 Size:	806.5 KB ID:	3667999
      Thanks for the reply – and yes, I made a mistake with the 25Q16JWSIQ chip.
      I thought it was the BIOS and accidentally erased it, but I had made a backup first and reflashed it right after.
      I’ve attached that 2MB backup here, in case it’s helpful.
      I also took a clear photo of the motherboard (attached), but I really don’t see any second SPI flash chip – no 32MB chip anywhere visible.
      Only the 25Q16JWSIQ and a small 25X05CL.
      Graphic Card is 3070ti
      If you spot anything in the photo I missed, I’d really appreciate a hint.
      Thanks again!
      Click image for larger version  Name:	52D1E985-9CF4-4D4D-9ACF-39795CBF8D54.jpg Views:	0 Size:	806.5 KB ID:	3667998
      • volinakis
        • Jan 2021
        • 2739
        • N/A
        Thanks again!
        your photo looks like is made with Nokia 1000
        Take a look ... and post serial number and full model, as in rules of this forum.
        Click image for larger version  Name:	LENOVO5.png Views:	0 Size:	3.21 MB ID:	3668008
        • hyperwood
          • Jun 2025
          • 7
          Model: Lenovo IdeaPad 5 16ARH7H
          Serial number: PF3ZL6TE
          Motherboard: NM-E471 Rev. 2.0
          GPU: NVIDIA RTX 3070 Ti
          Found chips:
          • Winbond 25Q16JWSIQ (1.8V)
          • 25X05CL (very small EC chip)
          • and recently: XMC 25RU256CXIQ
            (possibly the real BIOS chip – 256Mbit, 1.8V)
          I’ll upload a proper dump from the XMC chip once I get stable contact using the 1.8V adapter.
          Thanks for your time.
          • hardware1
            • Sep 2021
            • 2936
            • N/A
            This could be your BIOS chip, we need a close image for it.
            • volinakis
              • Jan 2021
              • 2739
              • N/A
              Found chips:
              take care with your CH431A, do 3-4 readings and compare them, when you have 2 identical it means you have a good backup of bios chipset. I suppose that's why your vBios backup isn't good.
              • hardware1
                • Sep 2021
                • 2936
                • N/A
                Thanks again!
                I checked your 2MB file and it looks fine (It belongs to NVIDIA RTX 3070 TI Mobile 8 GB).
                You didn't tell us your device issue yet! We don't know why do you want to flash the BIOS?
                • hyperwood
                  • Jun 2025
                  • 7
                  Thanks for the tip.
                  I agree – it was probably a contact issue with the clip.
                  I’ve now taken a better photo of the XMC 25RU256CXIQ chip (attached here).
                  It’s extremely flat and hard to get stable contact with the clip.
                  I’ll try again using better pressure and double-check pin 1 orientation.
                  Once I manage to get a clean read (same data 2–3 times), I’ll upload the dump here.
                  The reason I’m trying to flash the BIOS:
                  The laptop shows no display at all, no Lenovo logo – just fans spinning and keyboard lighting briefly.
                  Even the BIOS recovery via USB stick didn’t work, so I suspect the BIOS may be corrupted (possibly from a previous freeze/crash).
                  That’s why I want to dump and reflash it externally.
                  Thanks again for your help and time.
                  • hardware1
                    • Sep 2021
                    • 2936
                    • N/A
                    Thanks for the tip.
                    It's WSON8 8*6 chip, SOIC8 clip will not work. So you have to use a special adapter for it, or Pogo-pins but I don't prefer that.
                    You're welcome.
                    • volinakis
                      • Jan 2021
                      • 2739
                      • N/A
                      You're welcome.
                      or he can solder wires to JP2.
                      • volinakis
                        • Jan 2021
                        • 2739
                        • N/A
                        Thanks for the tip.
                        you have to use 1.8V adapter, 25RU256CXIQ is powered with 1.8V, as well as 25Q16JW
                        • hardware1
                          • Sep 2021
                          • 2936
                          • N/A
                          Correct.
                          • Ponto da Manutenção
                            • May 2024
                            • 97
                            • Brasil
                            Below is your new file.
                            Your recorder model (CH341A) is not recommended for recording this type of Firmware.
                            • hyperwood
                              • Jun 2025
                              • 7
                              Thanks for confirming JP2 – that helps a lot.
                              Also thanks for the BIOS file.
                              I’ll try flashing it using CH341A with a 1.8 V adapter, wired directly to JP2.
                              Or do you recommend using a different programmer instead?
                                • May 2024
                                • 97
                                • Brasil
                                Your programmer (CH341A) is outdated.
                                I haven't used this model in years...
                                • hyperwood
                                  • Jun 2025
                                  • 7
                                  Yeah, CH341A is old. I know.
                                  It’s what I’ve got right now — not perfect, but it works (mostly).
                                  Flashing via JP2 is the current plan. If it fails, I’ll switch.
                                  Problem is: can’t find a solid modern programmer on Amazon Germany.
                                  Tons of clones. No real specs.
                                  Need a reliable tool. Suggestions?
                                  Thanks.
                                    • May 2024
                                    • 97
                                    • Brasil
                                    I have both of these models.
                                    Svod4.
                                    XGecu T76.
                                    • hyperwood
                                      • Jun 2025
                                      • 7
                                      Success! I managed to flash the BIOS using the XGecu T76 and direct wiring to JP2 with 1.8V.
                                      The system boots again and everything works fine now.
                                      Thanks to everyone who helped – especially for identifying the correct chip and pointing me to the right tools. Much appreciated! 🙏
                                      Thread can be closed.
                                      • JoWed
                                        Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                        by JoWed
                                        Hello Community,
                                        I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                        07-01-2025, 09:32 AM
                                      • Azurain
                                        Elitebook 840 G5 Bios Chip Soldering Question
                                        by Azurain
                                        I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                                        Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                                        04-14-2023, 06:58 PM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
                                      • Rdd KEuns
                                        Lenovo X1 Yoga Gen5 Full Bios chip dump request.
                                        by Rdd KEuns
                                        Hello, My lenovo x1 yoga gen5 laptop has been unstable and sometime freezes. After downgrading the bios i was normal for a moment but when back to being unstable.
                                        If anyone has an working bios please share it.
                                        Laptop lenovo x1 yoga gen5. serial number PF-2MSZ9Q. Type number 20UC-S2410N. Motherboard model number GX4A0/GY650 NM-C881 Rev1.0. Bios chip GD25B256DYIG...
                                        03-21-2025, 05:49 AM
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
