EZP2025 Working english program
  • ToNe 36
    • Mar 2025
    • 6
    • Romania
    Hello from Romania here I present you the working EZP2025 without using locale editor sent to me by the developer.
    It works without having to tweak it with locale emulator..
    I sent mails to the developer and he was kind enough to send me the fixed version which is not having the richedit error....
    Please save it and share it on other forums as well as the chinese man said he can not upload it on his website....strange....
    EZP 2025 works only with this version so it will not work with older versions.......
  • jerryormeno
    • Mar 2022
    • Lima
    Excelente compañero gracias totales.
    Excellent partner, thank you very much.
    in English please..
    • MMH3
      Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
      by MMH3
      i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
      Never ever i experienced problems with that.
      Now i have one 5050sff machine, where this jumper isnt working at all.
      I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
      The history of the machine is that i used it in my office...
      03-23-2025, 09:28 PM
    • DynaxSC
      GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
      by DynaxSC
      I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
      There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
      The board is generally working now, all PCIe ports are working, Windows installs normally.
      However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
      The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
      03-10-2025, 12:27 PM
    • ruletero
      how to program it8987E with Vertyanov? is not working
      by ruletero
      Hi
      somebody could explain me how to program ITE8987E with Vertyanov?
      MB: DAG3DBMB8D0 REv. D
      I can detect the EC but it not show the model, next I can read and try to erase but blank check is false.
      neither I can to write, it is false, below I add the log:
      ITE mode selected
      check pins ok
      selected motherboard DAG34AMB6D0 RV 15-AU IT8987E SHAN
      CHECK GND
      Now plug power to the motherboard
      Device ID: EEEE
      Device Revision: EE
      ITE series detected
      Flash ID: EEEEEE
      06-12-2023, 09:26 PM
    • obelix24
      Macbook Air 2020 (a2179) - touch id not working
      by obelix24
      Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
      I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
      02-09-2025, 12:57 PM
    • hopkok
      Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
      by hopkok
      Hi masters, I need your help.
      I am working on Lenovo Legion 16ITHg6
      Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
      INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
      My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
      AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
      Power LED is not working as well, power button working well.
      UI26 ??? is there any firmware too? Powered by +3VALW_AG.
      Motherboard...
      05-04-2025, 09:35 AM
