Pansonic CF-LX3EDKCS Error sending end of post message to ME, System HALT!
  • tacetzz
    • Jun 2025
    • 4
    • Viet Nam
    I have 2 Pansonic CF-LX3EDKCS, One is Error ME Region,I have backed up to restore the fault but it still shows an error as tiltle
    Help me to create a bios to fix error. Thank you
  • hoaca388
    Badcaps
    • Jan 2022
    • 12268
    Serial number ?
    • tacetzz
      • Jun 2025
      • 4
      • Viet Nam
      SN: 4AKSA18080
      Thank You!
      • shiyab
        • Sep 2023
        • 1592
        • india
        SN: 4AKSA18080
        Thank You!
        hi try and feedback
        • tacetzz
          • Jun 2025
          • 4
          • Viet Nam
          Hi Shiyab, i tried and still got error!
          I have backed up the bios file of the Laptop with SN 4AKSA25684 to restore the faulty laptop
          • rumpumpel1
            T490 error message 2203 Skip acknowledgement of an error message
            by rumpumpel1
            I have a T490 that displays the error message “2203: System configuration is invalid” immediately after the Lenovo logo every time it boots up.
            This message must be acknowledged with 'Esc'. On the one hand, I cannot eliminate the problem, on the other hand, I have not observed any other restrictions.
            Is it possible to change the BIOS so that this message no longer has to be acknowledged?
            MTM 20N3S19L00
            system SN PF1X4JP8
            board SN L1HF171000X...
            01-19-2025, 03:32 PM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            The TV does not turn on, the standby indicator is on. All voltages are present.
            Emms is dead. Not readable, not detected.
            Replaced emmc.
            But with another dump there is no launch
            Terminal log
            UART
            AC_ON
            RPMB key is not yet programmed
            HASH1_VERSION=0x00000000 64bit
            E-B
            FDE enabled
            layout pattern onebin by SAR7,0...
            06-01-2025, 02:11 AM
          • sushilachuthan
            APC UPS error P13
            by sushilachuthan
            one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
            the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
            The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
            We replaced the SCR with new device,, but the device is not power on as expected.
            Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
            09-26-2025, 09:00 AM
          • CapThatBrass
            CSE/Layout Project Error Message - FIT Tool
            by CapThatBrass
            Has anyone come across the attached error message whilst using CSME System Tools v16.0 r3.
            I've just loaded up an XML generated from the same application, and the error appears with no real clue as to how to fix it:
            Exception: Error occurred whilst trying to create container CseRegion. Reason Mismatch between CSE version and layout project version
            Layout Accepts: 16.0.x.y
            CseVersion: 16.1.25.2128
            Source: CsePlugin: CseRegion
            Source: CsePlugin
            Thanks in advance (hopefully someone knows....)...
            06-13-2023, 12:17 PM
          • Superbee_dad
            Sharp 80” long short flash backlight error - Help
            by Superbee_dad
            Hello Sharp TV experts
            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
            01-24-2025, 11:51 PM
