help need backup bios Asus m3400qa rev3.1
  • miscac
    • Feb 2018
    • 7
    • indonesia
    if someone have asus m3400qa rev3.1 bios
    Please share.
    Thanks in advance.​
  • peste
    • 13915
    • ROMANIA
    Please share.
    Thanks in advance.
    post S/N, full name and model, motherboard model, etc.
    post the contents of the bios chip even if it is corrupted..
    • miscac
      • Feb 2018
      • 7
      • indonesia
      ASUS Vivobook m3400Q,SN 24MN7N0CV05W76027H,
      Mainboard M3400QA R3.1 ,
      bios chips not readable.
      • onkar
        • Nov 2017
        • 16
        • India
        ok
          SMDFlea commented
          Editing a comment
          ok ? ,if you have files to share post them in a zip or rar archive.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
      • ferah831208
        help with bios decompose for Asus s5506ma
        by ferah831208
        I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
        08-24-2025, 05:35 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
