asus L506LHB bios
  • aldopc
    • Jul 2017
    • 468
    • Chilito
    asus L506LHB bios
    Hello friends, can someone repair my BIOS... asus L506LHB-HN326W SN R1NRCX03M78102A, I don't have an image... only the keyboard lights turn on...
  • hoaca388
    Badcaps
    • Jan 2022
    • 12226
    FX506LHB
    • aldopc
      • Jul 2017
      • 468
      • Chilito
      Thanks bro it worked perfectly
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • Kingblue
        Asus G750JX/JW problem with kb lights, USB ports and touchpad / Bios Problem?
        by Kingblue
        Hi im new here and i hope you guys can help me maybe.
        I buyed an old Asus G750JX and the seller told me it was running perfect after shutdown it never bootet again.
        So i buyed this G750JX and open it. after cleaning and checking all inside i startet it.
        It was booting perfectly. i played a clean win 8.1 on it.
        After installing all and update all to the last drivers it was running very good.
        Thinks that dont worked
        Keyboard back lights and cant start with fn+f4 all other fn+f working
        3 of the 4 USB 3 Ports are not working.
        the...
        03-20-2024, 05:31 AM
      • oragano
        ASUS ex-b250-V7 motherboard bios corrupted - by me
        by oragano
        hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
        So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
        i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
        10-17-2024, 02:53 AM
