Asus G750JX/JW problem with kb lights, USB ports and touchpad / Bios Problem?
  • Kingblue
    • Mar 2024
    • Deutschland
    Hi im new here and i hope you guys can help me maybe.
    I buyed an old Asus G750JX and the seller told me it was running perfect after shutdown it never bootet again.
    So i buyed this G750JX and open it. after cleaning and checking all inside i startet it.
    It was booting perfectly. i played a clean win 8.1 on it.
    After installing all and update all to the last drivers it was running very good.
    Thinks that dont worked
    Keyboard back lights and cant start with fn+f4 all other fn+f working
    3 of the 4 USB 3 Ports are not working.
    the right bump of the touchpad also dead.
    Bios was the right one installed 209
    ATK files and all other driver was installed and any times reinstalled to test.
    all i do was not bring back any of this.
    I flashed via emergency flash a dump 206 bios on it reinstaled all drivers also ATK and nothing changed.
    i opend the laptop again. There i see that the board is not a JX. it is an JW.
    i tryed to flash the right bios for the JW. But it tells me all time that this is not possible with different apps.
    I also tryed with the Gary Key fix to solve the problems. but also without any luck.
    I tryed with the AFUWIN to change something in the bios. but also all i do was not helpfull.
    i also tryed all this steps on Win 10 with the Win 10 Drivers. its the same.
    Anyone here have any idea how to bring back the not working parts?
    im google allready 2 weeks about this.
    I know its an older Laptop but its still good for my kids.
    I founded many posts about this but all of this was not working.
    thanks for our time
    Edit:
    I also own a G750JS that works perfectly. i also tryed the Keyborad from the JX/JW on the JS and there all was working.
  • Kingblue
    • Mar 2024
    • Deutschland
    no one any idea?
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      Yesterday, 04:04 PM
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • traxformania
      TONGFANG "GM7TG7P" Bios Password Problem?
      by traxformania
      I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
      But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
      I'm trying to reset my bios without success.
      I tried :
      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
      11-15-2023, 07:32 AM
    • trouble55
      NEC VersaPro PC-VRT42FBFR22B BIOS problem
      by trouble55
      Hi All,
      [Mother board model]
      V-VE212(U3E1)
      [Serial number]
      24000135PA
      [BIOS chip model]
      Macronix MX77L12850F
      I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
      I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
      I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
      09-19-2024, 01:24 AM
