15-n096sa BIOS EXE
  • DiamondTech61
    • Aug 2021
    • 61
    • united kingdom
    15-n096sa BIOS EXE
    Hi, I have a HP 15-n096sa with a corrupted BIOS, it has 2 flashes on caps lock but the HP site no longer has the BIOS file to install to a USB stick
    Product is F4T58EA##ABU
    Can i have a BIOS setup file to create a USB stick to boot from?
    • 21164
    this might help - https://h30434.www3.hp.com/t5/Notebo...y/td-p/9151198
    • DiamondTech61
      • Aug 2021
      • 61
      • united kingdom
      YES, thats perfect, thank you so much!
        SMDFlea commented
        Editing a comment
        You`re welcome ;-)
    • traxformania
      TONGFANG "GM7TG7P" Bios Password Problem?
      by traxformania
      I tried :
      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
      11-15-2023, 07:32 AM
    • Forest79
      by Forest79
      However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
      07-23-2023, 07:39 AM
    • Sebastian Codrean
      BIOS file for ASUS F542UN laptop
      by Sebastian Codrean
      Hello to all of you! I need help with a BIOS file.
      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
      02-20-2025, 10:25 AM
    • Fr33man
      BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
      by Fr33man
      I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
      *Novo button power on
      *Disconnected internal battery...
      09-23-2024, 01:16 PM
    • Loli Popu
      DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
      by Loli Popu
      Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
      12-13-2024, 08:29 AM
