15-n096sa BIOS EXE
  • DiamondTech61
    • Aug 2021
    • 63
    • united kingdom
    15-n096sa BIOS EXE
    Hi, I have a HP 15-n096sa with a corrupted BIOS, it has 2 flashes on caps lock but the HP site no longer has the BIOS file to install to a USB stick
    Product is F4T58EA##ABU
    Can i have a BIOS setup file to create a USB stick to boot from?
    • 22286
    this might help - https://h30434.www3.hp.com/t5/Notebo...y/td-p/9151198
    • DiamondTech61
      • Aug 2021
      • 63
      • united kingdom
      YES, thats perfect, thank you so much!
        SMDFlea commented
        Editing a comment
        You`re welcome ;-)
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • traxformania
      TONGFANG "GM7TG7P" Bios Password Problem?
      by traxformania
      I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
      But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
      I'm trying to reset my bios without success.
      I tried :
      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
      11-15-2023, 07:32 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
    • Sebastian Codrean
      BIOS file for ASUS F542UN laptop
      by Sebastian Codrean
      Hello to all of you! I need help with a BIOS file.
      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
      02-20-2025, 10:25 AM
