HP 15-bs058nf Corrupted bios
  • KoSLoW
    • May 2025
    • 5
    • France
    I'm looking for the correct BIOS for my HP 15-bs058nf laptop.
    The official update from HP bricked my system — the screen went black and I'm unable to recover it using a USB drive.
    I extracted the BIOS files from the official InsydeFlash executable and ended up with the following files:
    • 084D4.bin (8192 KB)
    • 084D4.sig (1 KB)
    • 0832D.bin (8192 KB)
    • 0832D.sig (1 KB)
    • 0832E.bin (8192 KB)
    • 0832E.sig (1 KB)
    • 08328.bin (8192 KB)
    • 08328.sig (1 KB)
    • 08445.bin (8192 KB)
    • 08445.sig (1 KB)
    Unfortunately, I didn't save the original BIOS because it was already corrupted by the update, so I erased the chip using my T48 programmer.
    Here's what I've tried so far:
    • 0832D.bin → no fan spinning, no boot
    • 0832E.bin → no fan spinning, no boot
    • 084D4.bin → no fan spinning, no boot
    Can anyone help me identify the correct BIOS to flash?
    Motherboard reference: CSL50/CSL52 LA-E791P Rev: 2.0
    I use T48 programmer with Xgpro v12.88
    Thanks in advance!​
  • danito
    • Jun 2016
    • 901
    • Romania
    post the original bios of the laptop even if it is corrupted
      • 20795
      Post the laptop serial number -> https://www.badcaps.net/forum/troubl...before-posting
      • KoSLoW
        • May 2025
        • 5
        • France
        Ok sorry.
        There is the serial number : SN# CND808427S
        i also join the bios backup i made with a CH341A usb key but i'm not sure about the file because the usb key do not work correctly :/
        Thanks !
        • danito
          • Jun 2016
          • 901
          • Romania
          Ok sorry.
          Thanks !
          read again. not good.
            • 20795
            Ok sorry.
            Thanks !
            Try this bios.
            • KoSLoW
              • May 2025
              • 5
              • France
              SMDFlea Sorry for the late reply. I just flashed your BIOS and it works!!
              However, I get an error at startup: "Manufacturing Programming Mode is in Unlock Mode."
              I saw a video about using the HP BIOS Configuration Utility to fix this.
              I checked the TXT file, and the SKU (part number) doesn't match the one I found on HP PartSurfer:
              https://partsurfer.hp.com/?searchtext=CND808427S
              In the TXT file I get: SKU Number: 2PW31EA#ABU
              But on HP PartSurfer it shows: Product Number: 2MG02EA
              or do you think i can try recovery usb key to attemp a perfect setting ? (The computer's battery is dead, which might be the reason the update failed.)
              What should I do?
              Huge thanks again for your help!!
                • 20795
                What should I do?
                Change the info in the config.txt , save it then lock MPM
                • KoSLoW
                  • May 2025
                  • 5
                  • France
                  Everything is working correctly now. Thank you for saving my BIOS. I've made a PayPal donation for a drink. Much appreciated! ✌🏻
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • q2v5
                    Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                    by q2v5
                    Lenovo T480s
                    Model 20L8-S3TE00
                    Board ET481-U10
                    Chip MX25L12873F
                    Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                    2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                    The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                    08-15-2024, 10:40 PM
                  • TylerHyde21
                    Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                    by TylerHyde21
                    Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                    I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                    I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                    This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                    06-29-2024, 10:38 AM
                  • Loli Popu
                    DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                    by Loli Popu
                    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                    12-13-2024, 08:29 AM
                  • Max029
                    Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                    by Max029
                    I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                    I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                    TY,
                    08-18-2024, 08:28 PM
