HP 15-bs058nf Corrupted bios
  • KoSLoW
    • May 2025
    • 5
    • France
    I'm looking for the correct BIOS for my HP 15-bs058nf laptop.
    The official update from HP bricked my system — the screen went black and I'm unable to recover it using a USB drive.
    I extracted the BIOS files from the official InsydeFlash executable and ended up with the following files:
    • 084D4.bin (8192 KB)
    • 084D4.sig (1 KB)
    • 0832D.bin (8192 KB)
    • 0832D.sig (1 KB)
    • 0832E.bin (8192 KB)
    • 0832E.sig (1 KB)
    • 08328.bin (8192 KB)
    • 08328.sig (1 KB)
    • 08445.bin (8192 KB)
    • 08445.sig (1 KB)
    Unfortunately, I didn't save the original BIOS because it was already corrupted by the update, so I erased the chip using my T48 programmer.
    Here's what I've tried so far:
    • 0832D.bin → no fan spinning, no boot
    • 0832E.bin → no fan spinning, no boot
    • 084D4.bin → no fan spinning, no boot
    Can anyone help me identify the correct BIOS to flash?
    Motherboard reference: CSL50/CSL52 LA-E791P Rev: 2.0
    I use T48 programmer with Xgpro v12.88
    Thanks in advance!​
  • danito
    • Jun 2016
    • 1097
    post the original bios of the laptop even if it is corrupted
      • 21936
      Post the laptop serial number -> https://www.badcaps.net/forum/troubl...before-posting
      • KoSLoW
        • May 2025
        • 5
        • France
        Ok sorry.
        There is the serial number : SN# CND808427S
        i also join the bios backup i made with a CH341A usb key but i'm not sure about the file because the usb key do not work correctly :/
        Thanks !
        • danito
          • Jun 2016
          • 1097
          Ok sorry.
          Thanks !
          read again. not good.
            • 21936
            Ok sorry.
            Thanks !
            Try this bios.
            • KoSLoW
              • May 2025
              • 5
              • France
              SMDFlea Sorry for the late reply. I just flashed your BIOS and it works!!
              However, I get an error at startup: "Manufacturing Programming Mode is in Unlock Mode."
              I saw a video about using the HP BIOS Configuration Utility to fix this.
              I checked the TXT file, and the SKU (part number) doesn't match the one I found on HP PartSurfer:
              https://partsurfer.hp.com/?searchtext=CND808427S
              In the TXT file I get: SKU Number: 2PW31EA#ABU
              But on HP PartSurfer it shows: Product Number: 2MG02EA
              or do you think i can try recovery usb key to attemp a perfect setting ? (The computer's battery is dead, which might be the reason the update failed.)
              What should I do?
              Huge thanks again for your help!!
                • 21936
                What should I do?
                Change the info in the config.txt , save it then lock MPM
                • KoSLoW
                  • May 2025
                  • 5
                  • France
                  Everything is working correctly now. Thank you for saving my BIOS. I've made a PayPal donation for a drink. Much appreciated! ✌🏻
                  • kenkaniff
                    HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                    by kenkaniff
                    Product Name: HP Pro x360 Fortis 11-inch G9
                    System BIOS: U94 Ver.01.08.00 10/06/2023
                    Serial Number: 5CG31946F5
                    SKU Number: 85W05EC#AK8
                    Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                    This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                    I needed to remove bios password...
                    10-01-2025, 04:32 AM
                  • zlr8r
                    Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                    by zlr8r
                    Greetings
                    I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                    Serial Number: 5CG3202C16
                    Product #/SKU: 739P0AV
                    CT Number: PRTUE00WBI30YX
                    Description: HP ZBook Firefly 14 inch G10
                    BuildID: 23WWWGAZ602#SABU#DABU
                    Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                    MAC address not found.
                    • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                    10-28-2025, 01:56 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • q2v5
                    Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                    by q2v5
                    Lenovo T480s
                    Model 20L8-S3TE00
                    Board ET481-U10
                    Chip MX25L12873F
                    Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                    2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                    The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                    08-15-2024, 10:40 PM
                  • TylerHyde21
                    Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                    by TylerHyde21
                    Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                    I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                    I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                    This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                    06-29-2024, 10:38 AM
