Omen 15-dc1056nf (Need Dump Bios or something ) Thanks :(
  • DavidJocic
    • Apr 2025
    • 10
    • france
    Hello everyone firstly i'm thankfully if someone can help me if not i'm very stupid i have use ch341-a to flash my bios when i was deleted chip and loose my original backup, then the problem comes my laptop won't start only red light blinking without boot and without screen and fans but electricity is there in light close to charger. Chip was not damaged cause via application works when i want to update. Probleme is next i even tryed to download official bios from hp and put there informations of my serials numbers which is : 5CD938GPG1 (with HxD ). My model is with chip name winbond 25Q128JVSQ 1931. And my initial bios before works was version f.29 smbios 3.2. I have tryed everything on the world, always same thing red light and no any problem with verify, erase and program. Always succesful. I have one of my backup which is corrupted i don't know why didn't save good. Just want to repair and i will not touch bios anymore thanks again
  • hoaca388
    Badcaps
    • Jan 2022
    • 12139
    OMEN by HP 15-dc1056nf
    • DavidJocic
      • Apr 2025
      • 10
      • france
      Hello, I'm thankfully I test that after job. I spend don't know how much time to make it work and anything I keep you informed
      Thanks again
      • DavidJocic
        • Apr 2025
        • 10
        • france
        hoaca388 Still same problem I did read - erase - verify - program - verify all success but still I got only red light blinking no start no vents anything
        • hoaca388
          Badcaps
          • Jan 2022
          • 12139
          Check hardware problem.
          • DavidJocic
            • Apr 2025
            • 10
            • france
            Any hardware problem anything broken. Everything is like always , I know that is bios problem because last file I didn't even get red light. With that file you send me I got red light blinking with no starting but doesn't know where to start looking for solution. Cause because before flashing any problem software also chip is not damaged if hardware what you think
            • DavidJocic
              • Apr 2025
              • 10
              • france
              I didn't have any hardware problem before flashing and I know that is not problem with hardware cause with my bios before I didn't even get red light anything now I got power but red light blinking. Also chip reading is okay, doesn't know what to look for solution
              • DavidJocic
                • Apr 2025
                • 10
                • france
                !BUMP someone have another file to test guys?
                  • 21472
                  Try some older bios versions, there`s around 15 at HP support. Download and run the exe, choose to save to a location.
                  • DavidJocic
                    • Apr 2025
                    • 10
                    • france
                    SMDFlea Thanks for your answer I have checked any component in PC is damaged. Everything is okey, only one problem is that on HP drivers website I can find only one for my model the last one. Second thing is that I hear when we download bios from HP we can't put it with ch341 directly on chip cause there is not all information about PC and there is thing that is not ready. I don't know if is true. But only thing that I know since I deleted chip any bios won't turn the PC. I just want give some try more before the PC is thrown. Thanks again, I even did checksum verification after programming bios from other member but still on red light no fans anything
                      • 21472
                      Bios F28 + DMI.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12139
                        Older version .
                        • DavidJocic
                          • Apr 2025
                          • 10
                          • france
                          i tryed the version v11 noting happenned , same thing . But will try every one else and i did read the smallest chip 1mb mx25u8035e. So i have see on the internet, that this chip also can cause that pc won't turn on, don't know how to check if is corrupted i have checked via amibcp but can't open. So where i can find this one which is not corrupted or for trying other one?
                            • 21472
                            That`s the NVIDIA vBios.
                            • MDSI
                              HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                              by MDSI
                              I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                              Details:
                              Model : HP OMEN 17-an012nf
                              Motherboard Part Number : DAG3BAMBAF0 REV : F
                              Serial Number (S/N) : 5CD7280D51
                              BIOS chip : Winbond W25Q64VSIQ
                              Programmer : EZP2023+
                              Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                              I already...
                              07-28-2025, 07:11 AM
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • JoWed
                              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                              by JoWed
                              Hello Community,
                              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                              07-01-2025, 09:32 AM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • haitham sharabati
                              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                              by haitham sharabati
                              Hello engineers 😀,
                              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                              🔧 Device Info:
                              - Model: HP 15-da2007ne
                              - Product Number: 8XF55EA#ABV
                              - Serial Number: CND0338P0D
                              - CPU: Intel Celeron N4000
                              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                              💀 Problem:😅
                              - Device shows “Administrator Password”...
                              08-07-2025, 04:54 AM
