Bios from different manufacturer
  • g0rak
    • May 2014
    • 10
    • Czech Republic
    Hi, I gotta Acer NB , got myself replacement Mobo, originating from PackardBell. Motherboards are same with only difference name of NorthBridge, original Acer states RS880 , while current PackBell got RS780M. Everything else is same , even those chips soldered on Mobo got same "names".
    I wonder If its :generaly: safe to put Acer BIOS into this PackBell mobo. My concern is really fucked up Keyboard layout by PackBell.
    Thx for anything =)
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Bios from different manufacturer
    maybe, but aftermarket MFG's like parkerd hell can use a different northbridge or KBC and thus cause the need for a modded BIOS. in my case i have done that before, on the computer i am typing on now, it had a modded by powerspec BIOS and i replaced it with the stock Intel BIOS because it was severely buggy and won't boot from network or add on cards. that worked because ALL the chips are original to Intel.
    just use a second BIOS chip for Acer's BIOS and don't overwrite the current one with the packard hell BIOS on it.
    Follow the white rabbit.
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • AppleLover123
      Acer Aspire A315-56-37qb mobo fried after programmed bios
      by AppleLover123
      Hello guys,
      i've got this Laptop from ebay the bios was bricked. I bought it a few weeks ago and flashed it with
      a CH341A Programmer first (Bios.bin attached) all that went good my bios worked and it booted up afterwards.
      Now i used it and wanted more memory so i went from a 4 GB 1Rx16 to a 16GB 1Rx8 .
      But it wont boot up with the new ram stick that i checked before in another laptop then i thought it was a good idea to flash the bios again
      with the same .bin so i dissasembled the laptop and took out the mobo and flashed the bios again (same way i did it before)...
      11-09-2024, 05:42 AM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
