Need BIOS ROG GU604VI
  • danielFAB
    • Jul 2016
    • 29
    • Argentina
    Hi everyone, I need help.
    I have a ROG with a corrupted BIOS. It turns on without video.
    Already tried to perform a ME clean on 'ORIGINAL.bin' with UEFITool, but it informed me that the image is protected
    And I also tried to extract the .bin from the one downloaded from the Asus website, but the same thing happened because the image was protected so I couldn't move forward.
    Can you help me?
    ASUS ROG ZEPHIRUS M16
    model GU604VI-M16.I94070
    sn R6NRKD01700426C
    ORIGINAL.zip Please clean ME
    GU604VIAS313.zip I need to extract virgin bios.bin without DMI
    Thanks in advance
  • shiyab
    • Sep 2023
    • 1696
    • india
    Can you help me?
    sn R6NRKD01700426C
    Thanks in advance
    hi try
    • doivaythoiem
      • Jun 2024
      • 126
      • Việt Nam
      try and feedback
      • danielFAB
        • Jul 2016
        • 29
        • Argentina
        Originally posted by shiyab
        hi try
        Thanks for integrating the BIOS.
        I've tested it and it works perfectly
        Thank you so much!​
        • danielFAB
          • Jul 2016
          • 29
          • Argentina
          Originally posted by doivaythoiem
          try and feedback
          Thank you very much for BIOS clean ME
          I have tested it and everything works fine
          • kingkong computers
            • Sep 2018
            • 214
            • pakistan
            clear me display
            modle gu604vi-m16-i94070
            sn. rcnrkd003152498
            • shiyab
              • Sep 2023
              • 1696
              • india
              Originally posted by kingkong computers
              clear me display
              sn. rcnrkd003152498
              hi try
              • rajeshks
                • May 2009
                • 35
                Please Clear my file. When updating time systm offed. Now display not coming.
                Serial No: R4NRKD028546167
                Board No: GU604VI-PMV-VGT
                6050A3455101-MB-A01
                • shiyab
                  • Sep 2023
                  • 1696
                  • india
                  6050A3455101-MB-A01
                  hi try
                  • rajeshks
                    • May 2009
                    • 35
                    hi try
                    Thanks for your Respond.
                    This file unit not powering on. Before powering on and display not coming.
                    • rajeshks
                      • May 2009
                      • 35
                      6050A3455101-MB-A01
                      Please clear my file.
                        • 22286
                        Can you explain what you meant by "When updating time systm offed" .
                        • Pooshoes
                          • Mar 2022
                          • 12
                          shiyab is it possible to edit a bios with my serial number after flashing or must we create a new file? I used yours above to restore function to my pc but it will not connect to Asus cloud recovery without the right info in the bios.
                          Thank you!
                            • 22286
                            Thank you!
                            If you made a bios backup and if the DMI area with the serial number is intact then it can be copied from the backup to the new bios using a hex editor.
                            • Pooshoes
                              • Mar 2022
                              • 12
                              Hello, thanks for your help.
                              Attached is the backup
                              SN:R2NRKD005606083
                              I've searched through the backup for that string using HxD. How did you figure out the address to copy the info from the old one into a working one?
                              Thanks again
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12441
                                SN:R2NRKD005606083
                                Thanks again
                                ROG Zephyrus M16 (2023)_GU604VI
                                • Pooshoes
                                  • Mar 2022
                                  • 12
                                  Bravo, the bios did work and I was able to connect to ASUS Recovery. Thank you for your help! Did you have a resource or utility where I could learn to extract original bios from ASUS and which sections to copy over?
                                  Thanks again,
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • survivalbloke
                                    Unable to extract bios file from Lenovo bios exectuable
                                    by survivalbloke
                                    I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                    Code:
                                    "innoextract 7wcn38ww.exe"
                                    it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                    The trouble I'm having is that I'm not getting the newly...
                                    06-12-2024, 07:55 AM
                                  • istvanszasz99
                                    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                    by istvanszasz99
                                    Product Name: Razer Blade 15 (2022)
                                    Product ID: RZ09-0421
                                    Motherboard: CH580
                                    BIOS Versions I work with: 2.02 & 2.06
                                    Bios File Size: 32,768 KB
                                    Dear Forum Readers!
                                    I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                    I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                    The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                    !!! MY RAZER BLADE...
                                    11-24-2025, 05:52 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
