Need BIOS ROG GU604VI
  • danielFAB
    • Jul 2016
    • 29
    • Argentina
    Hi everyone, I need help.
    I have a ROG with a corrupted BIOS. It turns on without video.
    Already tried to perform a ME clean on 'ORIGINAL.bin' with UEFITool, but it informed me that the image is protected
    And I also tried to extract the .bin from the one downloaded from the Asus website, but the same thing happened because the image was protected so I couldn't move forward.
    Can you help me?
    ASUS ROG ZEPHIRUS M16
    model GU604VI-M16.I94070
    sn R6NRKD01700426C
    ORIGINAL.zip Please clean ME
    GU604VIAS313.zip I need to extract virgin bios.bin without DMI
    Thanks in advance
  • shiyab
    • Sep 2023
    • 1592
    • india
    Can you help me?
    sn R6NRKD01700426C
    Thanks in advance
    hi try
    • doivaythoiem
      • Jun 2024
      • 124
      • Việt Nam
      try and feedback
      • danielFAB
        • Jul 2016
        • 29
        • Argentina
        Originally posted by shiyab
        hi try
        Thanks for integrating the BIOS.
        I've tested it and it works perfectly
        Thank you so much!​
        • danielFAB
          • Jul 2016
          • 29
          • Argentina
          Originally posted by doivaythoiem
          try and feedback
          Thank you very much for BIOS clean ME
          I have tested it and everything works fine
          • kingkong computers
            • Sep 2018
            • 210
            • pakistan
            clear me display
            modle gu604vi-m16-i94070
            sn. rcnrkd003152498
            • shiyab
              • Sep 2023
              • 1592
              • india
              Originally posted by kingkong computers
              clear me display
              sn. rcnrkd003152498
              hi try
              • rajeshks
                • May 2009
                • 34
                Please Clear my file. When updating time systm offed. Now display not coming.
                Serial No: R4NRKD028546167
                Board No: GU604VI-PMV-VGT
                6050A3455101-MB-A01
                • shiyab
                  • Sep 2023
                  • 1592
                  • india
                  6050A3455101-MB-A01
                  hi try
                  • rajeshks
                    • May 2009
                    • 34
                    hi try
                    Thanks for your Respond.
                    This file unit not powering on. Before powering on and display not coming.
                    • rajeshks
                      • May 2009
                      • 34
                      6050A3455101-MB-A01
                      Please clear my file.
                        • 21679
                        Can you explain what you meant by "When updating time systm offed" .
                        • Pooshoes
                          • Mar 2022
                          • 12
                          shiyab is it possible to edit a bios with my serial number after flashing or must we create a new file? I used yours above to restore function to my pc but it will not connect to Asus cloud recovery without the right info in the bios.
                          Thank you!
                            • 21679
                            Thank you!
                            If you made a bios backup and if the DMI area with the serial number is intact then it can be copied from the backup to the new bios using a hex editor.
                            • Pooshoes
                              • Mar 2022
                              • 12
                              Hello, thanks for your help.
                              Attached is the backup
                              SN:R2NRKD005606083
                              I've searched through the backup for that string using HxD. How did you figure out the address to copy the info from the old one into a working one?
                              Thanks again
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12268
                                SN:R2NRKD005606083
                                Thanks again
                                ROG Zephyrus M16 (2023)_GU604VI
                                • Pooshoes
                                  • Mar 2022
                                  • 12
                                  Bravo, the bios did work and I was able to connect to ASUS Recovery. Thank you for your help! Did you have a resource or utility where I could learn to extract original bios from ASUS and which sections to copy over?
                                  Thanks again,
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • survivalbloke
                                    Unable to extract bios file from Lenovo bios exectuable
                                    by survivalbloke
                                    I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                    Code:
                                    "innoextract 7wcn38ww.exe"
                                    it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                    The trouble I'm having is that I'm not getting the newly...
                                    06-12-2024, 07:55 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
