need bios fix for Asus X1603Z mainboard X1403ZA rev2.1
  • crystalsound
    • 15
    • italy
    Hi guys, I need the bios fix for the model as in title. The laptop shows blinking battery led, the battery doesn't charge at all and the voltages are all present. I post here the dump of the bios ic, read using a TL866.
    Model: X1603Z
    SN: N7N0CX065847284
    Mainboard: X1403za R2.1
    Thanks to everybody.
    • 21922
    Model: X1603Z
    SN: N7N0CX065847284
    Post a picture of the QR code on the motherboard
    • crystalsound
      • 15
      • italy
      There it is.
      • crystalsound
        • 15
        • italy
        I mean, if there is a guide or something I could do it myself. Otherwise, I would appreciate a lot for the support.
          • 21922
          The serial number from the QR code is different to the one you posted. N728NBCX007P63MB .Do you want a bios with the current SN or the one from the QR
          QR
          N728NBCX007P63MB
          QCCXJI0QB22800223
          X1603ZA
          60NB0WB0-MB2030 212​
          • crystalsound
            • 15
            • italy
            The serial number i've written in the first post is on a QR code on a sticker in the back cover. The QR code I last posted is on the motherboard, so I guess this one is the correct one, am I right? I don't really know why they do not match, maybe this is not the original motherboard for this chassis, I don't know. But imho I need to go with the motherboard SN.
              • 21922
              try this bios.
              • crystalsound
                • 15
                • italy
                Thank you but still nothing. Not doing anything, only slowly blinking side white led.
                • crystalsound
                  • 15
                  • italy
                  As I said before, is there a sort of guide to follow to fix these files so that I can try myself? The problem seems to have already arisen before to other people, and as far as I've read, it has been fixed. Thank you
                  • crystalsound
                    • 15
                    • italy
                    No help at all?
                      • 21922
                      No help at all?
                      I think the bios i posted is good, but until someone confirms it`s working or not we won`t know. If you can find a schematic/repair guide test hardware.
                      • crystalsound
                        • 15
                        • italy
                        Many people around here and other places have experienced this blinking power led and nothing more, and solved with a bios fix. I have all voltages, including obviously the 3.3 for the bios chip, nothing more than that.
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
