ASUS G513R-MV-VT
  • nissimezra
    • 178
    ASUS G513R-MV-VT
    Device: Laptop
    Brand: Asus
    Model: G513RM-A571-CA
    Board number: G513R-MV-VT
    Serial number: N2NRKD035375079
    Request: BIOS dump
    Problem,: Black screen
    CPU Ryzen 7
    Many thanks
  • doivaythoiem
    • Jun 2024
    • 124
    • Việt Nam
    try
    • nissimezra
      • 178
      Originally posted by doivaythoiem
      try
      Thank you for trying to help!
      Its still the same black screen. no vcore no GPU voltage, Ram voltage present.
      If anyone has a known working bios please share it
      • doivaythoiem
        • Jun 2024
        • 124
        • Việt Nam
        bios OK. check mainboard
        • nissimezra
          • 178
          thank you very much for your help. Probably the problem is the main board
          I never had luck repairing no vcore voltage.
          thanks again
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • Technodoc
            ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
            by Technodoc
            Asus laptop G614JZ-N3012W Rog Strix with i7
            Mainboard G634J-PMV-VGT
            6050A3441302-MB-A01
            2023-02-10
            Power button works okay....power light goes on
            Red "bottom" leds go on
            Charging led works
            Fans do not spin, capslock key does nothing, screen stays black
            I would like to program the bios again, to rule out a corrupted bios.
            However I run into a size error
            The bios chip is a Winbond 25R256JVEN
            Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
            02-24-2025, 04:46 AM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
