BIOS for Lenovo Yoga 6 13ALC7
  • Loki_Fido
    • Mar 2025
    • 135
    • Japan
    Hi folks,
    This BIOS file is from a fully functional Lenovo Yoga 6 13ALC7.
    If you have trouble reading the BIOS chip, go to this link and read the complete thread.
    https://www.badcaps.net/forum/troubl...os#post3565103
    Don't use 1.8v adapter.
    I love you all
  • verymessi
    • May 2025
    • 5
    I have a corrupted BIOS on a replacement motherboard for my Lenovo Yoga 6 13ALC7 Type 82UD and I am not sure exactly how to go about fixing it.
    I wanted to upgrade my laptop's motherboard from the 8GB Ryzen 5 5500U CPU variant to the 16GB Ryzen 7 5700U variant. I replaced the motherboard, and on the first boot with the new motherboard, the BIOS went to recovery and the BitLocker screen came on. I was not able to add my activation key before the laptop automatically shut off, and ever since then I am met with a black (but still on) display whenever I turn on the computer. Given that it was able to boot on the first time around, I figure it must be a corrupted BIOS.
    I thought that I can just flash the working BIOS from my old motherboard onto this new motherboard. However I found another BIOS (follow this link) here on Badcaps, and I found using WinMerge that there are many differences in the content of the BIOS between that copy and the one I pulled from my old working motherboard. The BIOS in the link is also for the 8GB Ryzen 5500U variant (I checked from the serial number). I thought that BIOS for the same motherboard should be identical (except for the serial number I guess). Now I don't know which BIOS is the correct one to flash.
    My question is that should I be flashing the BIOS from my old motherboard onto my new motherboard? They are the same model motherboard, just different memory and CPU. Or can the broken BIOS on my new motherboard be repaired? I appreciate any advice.
    New Motherboard Corrupted BIOS Attached
    Specs: 16GB Ryzen 7 5700U
    Mobo Model No.: HLC3A LA-M091P Rev 1.0
    Old Motherboard Working Bios Attached
    Specs: 8GB Ryzen 5 5500U
    • peste
      peste commented
      Editing a comment
      post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
    • 22279
    Please post the laptop serial number - https://www.badcaps.net/forum/troubl...before-posting
    • verymessi
      • May 2025
      • 5
      My Laptop Serial Number is MP27ZL5B
      • to5it0
        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
        by to5it0
        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
        I have opened the laptop and identified the main BIOS chip...
        10-24-2025, 01:35 AM
      • maeson
        BIOS Request - Lenovo Yoga L13 Gen3 (AMD)
        by maeson
        Hi dear Badcaps-Community,
        Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
        I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
        The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
        Lenovo Yoga L13 Gen 3 AMD:
        Lenovo Modell: Type 21BB
        Artikelnr.21BB006GGE
        Seriennummer: PW0A6207
        AMD Ryzen™ 5 PRO 5675U
        Memory 16 GB DDR4-3200MHz
        SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...
        10-31-2025, 03:08 AM
      • Udara Umayanga
        Need LA-M091 For Lenovo Yoga 6 13ALC7 Laptop Motherboard image
        by Udara Umayanga
        I need LA-M091 For Lenovo Yoga 6 13ALC7 Laptop Motherboard image for check missing parts..
        thanks,
        Udara
        11-07-2025, 06:46 PM
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • AYsys
        Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
        by AYsys
        Hello dear forum members,
        I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
        I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
        Nothing was flashed here — the BIOS was only backed up.
        I created the backup using a CH341A Black programmer and NeoProgrammer....
        09-13-2025, 11:05 AM
