15-dr1003la bios
  • layad
    • Nov 2011
    • 239
    15-dr1003la bios
    hi there ,
    hp envy x360 15-dr1003la
    sr 8cg0282nkz
    motherboard nr 18748-1
    , been fixed by replacing bios dump file with an other file from internet , the backup file exist but could not fix it at that moment
    need help fixing the orinal file , the file been downladed fron internet sometimes no working till i remove the battery an connect it again
    , need help fixing this file pls
  • lapfix
    • Mar 2020
    • 2564
    • my workshop
    Originally posted by layad
    hi there ,
    sr 8cg0282nkz
    HP ENVY x360 - 15-dr1003la
    F.19 Rev.A
    DMI+ Win Key =
    380000------381FFF
    Try and Give feedback
    • layad
      • Nov 2011
      • 239
      F.19 Rev.A
      DMI+ Win Key =
      380000------381FFF
      thanks , still the same result , only second file i uploaded works!
        • 20286
        There are 10 older bios versions at HP support, try some of those. You can extract them yourself.
        [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
        [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948​
        • layad
          • Nov 2011
          • 239
          in the original dump file 086b1 , the working file from internet is 085e6, tried some old ones all are 086b1 and not working, what does that means?
          the first time i worked on this laptop the power button was lighting up with no post or fan , tried repairing the backup file but always the same till i tried the one i downloaded , its for diffrent model number but same motherboard i think
            • 20286
            What model is the CPU and HP spare part number for the motherboard
            • layad
              • Nov 2011
              • 239
              hp spare part number is l65686-161 , cpu intel cor i5 10th gen
              • layad
                • Nov 2011
                • 239
                oh i think its l53569-601
                sounds like the motherboard been changed and it does not match with model number on the cover , most likely the actual model number is 15m-dr0012dx or 15m-dr0011dx
                • layad
                  • Nov 2011
                  • 239
                  flashed it with 15m-dr0012dx still the same
                  • Forest79
                    by Forest79
                    However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                    07-23-2023, 07:39 AM
                  • maanee11
                    Help to get Lenovo BIOS bin file for Thinkpad T560
                    by maanee11
                    Hello Everyone,
                    I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                    https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                    In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                    05-15-2022, 11:59 AM
                  • Sebastian Codrean
                    BIOS file for ASUS F542UN laptop
                    by Sebastian Codrean
                    Hello to all of you! I need help with a BIOS file.
                    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                    02-20-2025, 10:25 AM
                  • Fr33man
                    BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                    by Fr33man
                    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                    *Novo button power on
                    *Disconnected internal battery...
                    09-23-2024, 01:16 PM
                  • iZakre
                    HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                    by iZakre
                    Hello everybody!
                    To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                    The thing is that I had installed TeamViewer and could log into the computer...
                    02-19-2023, 02:27 PM
