Help me with unlock Dell Inspirion 13 7348
This topic has been answered.
  • jonyhdtv
    • Mar 2021
    • 18
    please help me remove password in BIOS in Dell Inspiron 7348
    BIOS A05
    System Disable
    [299E71BEA1A57DCD]
    Service Tag
    [C34YH52]
    I don't know what method to use for this model.
  • Answer selected by jonyhdtv at 01-30-2025, 02:05 AM.
    volinakis
    • Jan 2021
    • 2875
    • N/A
    BIOS A05
    System Disable
    [299E71BEA1A57DCD]
    Service Tag
    [C34YH52]
    try pass: 80643431 After type pass press and hold left Ctrl and hit Enter twice
    • Bornface Mulela
      • Jan 2025
      • Zambia
      What's the suffix code on the service tag?
      • Sahu ji
        • Dec 2024
        • 19
        • india
        BIOS A05
        System Disable
        [299E71BEA1A57DCD]
        Service Tag
        [C34YH52]
        send old backup file
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          BIOS A05
          System Disable
          [299E71BEA1A57DCD]
          Service Tag
          [C34YH52]
          • jonyhdtv
            • Mar 2021
            • 18
            It works thanks for the feedback. I didn't know that on beta.bios-pw.org I have to provide both numbers separated by "-" 299E71BEA1A57DCD-C34YH52
            But it's strange that I had to connect a USB external keyboard because after pressing Ctrl + Enter and an additional character popped up
            • volinakis
              • Jan 2021
              • 2875
              • N/A
              you are welcome. I use it without line between system disable and service tag
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • remizbushka
                Dell inspirion 5775 bios "Unlock Setup fail"
                by remizbushka
                Hi sirs. please help
                Dell Inspiron 5775 bios locked "Unlock Setup fail"
                After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                What I did:
                I read the bios dump.
                Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                03-24-2025, 09:07 AM
              • Akhlz001
                by Akhlz001
                09-20-2025, 07:15 PM
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
