Olivetti P55 black screen fix bios
  • reset1986
    • 308
    • italia
    Hi, we need to correct the bios for this model, I used a network bios that turns on but after about thirty seconds it emits beeps and turns off, I attach the original backup which gives a black screen
    Olivetti P55 model
    W650SJMB-0D motherboard
    sn NKW650SZ0005C02468
    Thank you
    • 22142
    post the laptop serial number.........................
    • reset1986
      • 308
      • italia
      NKW650SZ0005C02468
      • reset1986
        • 308
        • italia
        with this bios the pc turns on regularly and arrives in windows, after about 30 seconds it emits 22 beeps and the fan turns to maximum, then it turns off completely, I turn it back on and it does the same thing
        • reset1986
          • 308
          • italia
          Is it possible to correct the bios of the first post?thanks
          • volinakis
            • Jan 2021
            • 2875
            • N/A
            try celan_ME version, see if it helps
            • reset1986
              • 308
              • italia
              Thanks, but I still have a black screen, the problem lies in the 4 MB bios, if I load the bios of the 4 post of 4 MB the PC works and loads Windows, but lasts 30 seconds, start to issue 22bip and the fan at the max, Then he turns off
              • volinakis
                • Jan 2021
                • 2875
                • N/A
                try clean_ME bios from post 4
                • reset1986
                  • 308
                  • italia
                  ok, I try the bios, I did a search, this motherboard is mounted on the Clevo PC and has an Nvidia graphics card, my motherboard is one without a graphics card, only i5 CPU with integrated GPU, the 22 beeps indicate a problem with the sensor gpu which is not present on my main, I try this bios and update
                  • reset1986
                    • 308
                    • italia
                    then I did flash but still the 22 beeps and shutdown, then I found the 4MB file for the uma version of this main, I have the 2MB file cleaned by you and flash the 4MB one with this version that I attach, for those who have similar problems use the 4MB file, thanks
                    • mitchw
                      HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                      by mitchw
                      Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                      After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                      After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                      I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                      04-29-2025, 03:45 PM
                    • Technodoc
                      ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                      by Technodoc
                      Asus laptop G614JZ-N3012W Rog Strix with i7
                      Mainboard G634J-PMV-VGT
                      6050A3441302-MB-A01
                      2023-02-10
                      Power button works okay....power light goes on
                      Red "bottom" leds go on
                      Charging led works
                      Fans do not spin, capslock key does nothing, screen stays black
                      I would like to program the bios again, to rule out a corrupted bios.
                      However I run into a size error
                      The bios chip is a Winbond 25R256JVEN
                      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                      02-24-2025, 04:46 AM
                    • wizard13
                      Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                      by wizard13
                      I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                      I have checked the forum and the available documentation but could not find a solution specific to my issue.
                      • Brand & Model: Dynabook Satellite Pro C50D-B-100
                      • Part Number (P/N): PYU13E-00C00PFR
                      • Serial Number (S/N): 22028896H
                      • System Configuration (SC): A1PYU13E1127
                      • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                      • Power Input: DC 19V –
                      02-28-2025, 02:43 AM
                    • AgustinLorenzo
                      [BIOS REQUEST] HP Pavilion 15-BS521TU - Black screen after update BIOS to F.73
                      by AgustinLorenzo
                      Hi boys,
                      This is my first post in BADCAPS and I hope I don't make any mistakes and give the correct explanations.
                      Yesterday a friend brought me this laptop home to expand the RAM to 16GB of RAM and update it since it had been abandoned recently.
                      Everything was fine, until I made the mistake of updating the BIOS to version F.73 from version F.24, since after according to HP "updating correctly" the laptop never worked again, leaving the screen black but the fan is working and the light of M.2 is on.
                      After having carried out all the frequent...
                      10-15-2023, 07:31 AM
                    • amennone
                      Acer A315-24p-r2km , black screen. Bios
                      by amennone
                      Acer A315-24p-r2km Acer N23C3 snid: 32400005934 s/n NXKDEET00B3240003B3400 Main: IH5JM LA-M611P Rev: 1A
                      As per the title, the screen remains black. When the power button is pressed, the blue LED lights up, but the screen is black.
                      With an external monitor and HDMI output, there is no image. I loaded the following bins, same situation: ACER_A315_24P_IH5JM_LA_M611P_REV_1A_2022_08_22_WORKING_BIOS_100% IH5JM120.bin from this address https://www.badcaps.net/forum/troubl...a-m611p-rev-1a With the RT 809F programmer, I can't read the contents of the original XMC 25QU128CH1Q SPI, I get the...
                      07-31-2025, 04:19 PM
