ASUS FA506IU HN305 need bios dump
  • Bizonpatrol
    • Jun 2023
    • 11
    • Iowa
    Hi
    Need bios dump, dude entered the BIOS password and forgot it.
    ASUS FA506IU hn305
    dabkxbmbad0 rev d
    AMD Ryzen 5 4600H
    GeForce GTX 1660 Ti 6 Gb
  • peste
    • 12954
    • ROMANIA
    Originally posted by Bizonpatrol
    Hi
    ASUS FA506IU hn305
    dabkxbmbad0 rev d
    AMD Ryzen 5 4600H
    post S/N the original contents of the bios chip....you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    • Bizonpatrol
      • Jun 2023
      • 11
      • Iowa
      Have a problem with read bios chip! My Xgecu T48 don't see it, Winbond 25q128jwsm, but this chip are included in support list!
      • volinakis
        • Jan 2021
        • 2747
        • N/A
        set programmer to 1.8V
        • peste
          • 12954
          • ROMANIA
          select it manually...if it doesn't work select an equivalent chip..
          • Bizonpatrol
            • Jun 2023
            • 11
            • Iowa
            I choose this model at the list manualy and not working. tried read/write another chip - all good.
            I've ch341a, but don't remember in witch box)
            • Rebirth
              • Sep 2022
              • 50
              • Myanmar
              What is your serial number
              • Rebirth
                • Sep 2022
                • 50
                • Myanmar
                Try this bios
                • Bizonpatrol
                  • Jun 2023
                  • 11
                  • Iowa
                  s/n m2nrcx02667108a
                  • Bizonpatrol
                    • Jun 2023
                    • 11
                    • Iowa
                    I did it! Please clear password, if it possible.
                    • peste
                      • 12954
                      • ROMANIA
                      boot password....
                      2222
                      • Bizonpatrol
                        • Jun 2023
                        • 11
                        • Iowa
                        Unbelievable, bro, i was check 1111, 1234,0000
                        How can i thank you?
                        • Bizonpatrol
                          • Jun 2023
                          • 11
                          • Iowa
                          Originally posted by Rebirth
                          Try this bios
                          It's workihg. Thank you.
                          • Rebirth
                            • Sep 2022
                            • 50
                            • Myanmar
                            Happy to help
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • DynaxSC
                              by DynaxSC
                              06-14-2024, 03:49 PM
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • kodox
                              Asus ExpertBook B1400CB Bios Dump Needed
                              by kodox
                              need original bios dump, original bios has flashed by other technician before me.
                              attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                              unit info:
                              Model: Asus ExpertBook B1400CBA-0711A1235U
                              S/N: R6NXNZ006657238
                              CN: 7F6F
                              Mainboard Code: B1500CBA R2.1...
                              08-16-2025, 12:20 PM
