ned bios hp laptop 15-fd0000nx
  • beast4ever
    • Feb 2015
    • 174
    • egypt
    sn : 5cd336jxbh
    prodid : 8f1n4ea#a2n
    da0pdimb8g0 rev : g
    Gives energy for a moment and then turns off. No picture.
    • 22288
    Use the Guides to find and extract a virgin bios
    [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
    [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
    Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
    Offsets: 701000 - 7020FF and 7A6000 - 7A603F
    HxD Hex editor https://mh-nexus.de/en/hxd/​
    • Rebirth
      • Sep 2022
      • 50
      • Myanmar
      sn : 5cd336jxbh
      da0pdimb8g0 rev : g
      Here is your new bios. Try!!
      • beast4ever
        • Feb 2015
        • 174
        • egypt
        sn : 5cd336jxbh
        da0pdimb8g0 rev : g
        The file is fine
        Thank you friends, the problem is in the processor's country​
        • Bloodhoundje
          by Bloodhoundje
          03-16-2024, 03:12 PM
        • JoWed
          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
          by JoWed
          Hello Community,
          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
          07-01-2025, 09:32 AM
        • thxd43
          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
          by thxd43
          Hello, first of all, excuse me, I am using the translator, English is not my native language.
          I have a Lenovo ideapad 330S - 14IKB laptop.
          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
          02-23-2023, 08:37 PM
        • legendkray
          BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
          by legendkray
          I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
          07-05-2025, 09:25 AM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
