Asus Zephyrus GX550LWS bios request or fix
  • kalukramer
    • Nov 2023
    • 23
    • Portugal
    Hi.
    I have a Asus bricked after win11 auto update bios,
    Theres my bios in attache
    Need some help, thank's
  • shiyab
    • Sep 2023
    • 1646
    • india
    Originally posted by kalukramer
    Hi.
    post snid
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      Hi.
      Here is your New BIOS file, try it and let me know.
      Your Serial Number: "L6NRKD00706427E".
      all donations are welcome,
      • kalukramer
        • Nov 2023
        • 23
        • Portugal
        Thats correct that is serial number.
        I tried the bios you sent, and it still has the same symptom, it doesn't turn on. This has a second bios (EC) do you think it could be damaged too?
        • kalukramer
          • Nov 2023
          • 23
          • Portugal
          Originally posted by shiyab
          post snid
          • hardware1
            • Sep 2021
            • 2949
            • N/A
            Show me a clear image for the other chip.
            • kalukramer
              • Nov 2023
              • 23
              • Portugal
              • hoaca388
                Badcaps
                • Jan 2022
                • 12403
                This chip has nothing to do with the bios, don't touch it.
                • hardware1
                  • Sep 2021
                  • 2949
                  • N/A
                  As hoaca388 said, it's not a BIOS chip, it could be vBIOS or Thunderbolt firmware.
                  • kalukramer
                    • Nov 2023
                    • 23
                    • Portugal
                    OK
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • skipron.rm
                      ASUS Zephyrus GX701LXS BIOS request
                      by skipron.rm
                      Hello everyone, trust you're doing well.
                      I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
                      I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
                      However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
                      The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
                      My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...
                      Badcaps - Capacitor Search Engine & Electronics Repair Forum
                      12-11-2023, 06:12 PM
                    • skurvysyn
                      BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                      by skurvysyn
                      laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                      original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                      01-08-2025, 04:45 PM
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
