ASUS UX431FL REV 2.2 Bios need
  • hollo13
    • Mar 2017
    • 21
    • Hungary
    The laptop, not power on.Remove the battery cable, put ac adapter, machine is power on.
  • hollo13
    • Mar 2017
    • 21
    • Hungary
    SN : L6N0LP002434239
    The laptop, does not power on. If remove the battery cable, connect ac adapter, machine is power on.
    Thanks​
    • shiyab
      • Sep 2023
      • 1696
      • india
      Thanks​
      HI TRY
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • cyrgh
        After flashing bios, no power, nothing comes on ASUS K56CB
        by cyrgh
        Hi
        LAPTOP model: ASUS K56CB (i7-3537u cpu)
        BIOS POST took a long time, more than 30 seconds, it was never like this before. I decided to flash the bios using AFUDOS.exe.
        I downloaded the original BIOS file from Asus site ver205. I used RUFUS to create a boot-able USB flash having this command in AUTOEXEC.BAT:
        AFUDOS.exe BIOS.ROM /GAN
        It read the bios then gave the warning about writing to bios may ruin it. I confirmed and as soon as I pressed the enter key the power went out and it doesn't power on anymore. Even the battery power light does not turn...
        12-01-2023, 08:17 AM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
