here
					quanta R53 bios dump hp g6
Re: quanta R53 bios dump hp g6
hey i have a dell inspiron core i3. service tag: 83SMPY1...
Needs a bios reset and harddisk reset tooComment
HI! TNXXX!!!! X1000
God bless you!
Today I fixed the Bios Memory with External SPI FLASH MEMORY!
I have a HP pavilion G6 2105sa with motherboard serial R53!
The problem is : black screen is appear when I press the power button, The dedicated video chipset is not present on this motherboard and after I assumed that bios memory is corrupt!
I searched some days and I could`t find nowhere! I wrote only "bios R53 hp" an I found your .bin file!
Tnx dude you are my save!Comment
Hi
Yes when you download the update it needs to be unpacked look for the .fd ending open it with a text editor and compare with the original file if the file don't look alike then it's decryped and you need to run it threw a phoenix program in which it will leave you with a folder.. look for a BIO0 file now it's no longer decryped go back and compare with the original file if all looks good ending match now it's ready . If ending are different then you are trying to use the wrong file or version. then on HP you will need to run the DMI tool to serial # ,Make model and so on ..only other way if you know where to cut it out of original file and past this info in new bios will also work .. if you never done it it will take some practice or just upload it i will do for you.
Techman1025Comment
			by AhariHi all,
I...-
			by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
			Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
			by CityminHi all,
S/N : 5RNK9FFT70...-
 - Loading...
