Need BIOS/UEFI Unlocked for Toughbook CF-33
  • somedude001
    PC Tech
    • Nov 2024
    Client bought a used Toughbook CF-33 tablet computer. It has Windows 11 21H2 even though it does not support it (has a 7th gen i5) - ugh. The BIOS/UEFI is locked. His Bluetooth is totally missing so I need to unlock the BIOS to see if I can turn on Bluetooth within it.
    What to do? I know you can solder on a new BIOS chip, but that's beyond my capabilities. I am looking for an easy fix.
    Let me know if there's any other info needed.
  • somedude001
    PC Tech
    • Nov 2024
    Bump
      • 21692
      Originally posted by somedude001
      Bump
      Make a bios backup using an SPI programmer https://www.badcaps.net/forum/troubl...21#post1622421
      Post the backup in the bios requests section and someone will help to remove the password. No other way, no easy way.
      • somedude001
        PC Tech
        • Nov 2024
        Thank you. It definitely is not worth it. I have advised the client to simply add a USB Bluetooth adapter.
        • LiamK
          • Feb 2025
          I have the exact same issue with the bluetooth. My BIOS is also locked, and I'm not sure how to dump it. Any help? My SN should be 8ETTA41312
          • peste
            • 13451
            • ROMANIA
            you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
            • tlindi
              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
              by tlindi
              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
              >Read BIOS guides, methods, resources and tools
              Ack
              >Try the method at BIOS guides, methods, resources and tools before requesting help
              Ack
              >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
              python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
              01-30-2025, 04:26 AM
            • aa10aa10
              Panasonic Toughbook CF-33 mk1 BIOS repair
              by aa10aa10
              Good day,
              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
              01-21-2025, 06:13 AM
            • jhanra
              by jhanra
              11-02-2024, 04:19 AM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • GuiTi
              Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
              by GuiTi
              Hey everyone!
              I need help with my Lenovo Chromebook 100e Gen 3.
              Here are the details:
              • Motherboard: LA-L131P
              • MFG Date: 2022/01/07
              • MTM: 82J80001BR
              • MO: MPNXB2103001
              • Factory ID: LI123
              I bought a new Winbond 25Q128FVSG chip.
              The chip currently on the board is the same model but with different ending letters.
              I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
              The Chromebook is Google account locked, and I’ve already tried everything.
              I understand that I need to replace or...
              Yesterday, 08:41 AM
