Asus T103HAF BIOS flashed to a new chip not working
  • REpairAT
    • Nov 2020
    • 142
    • Austria
    I have an issue with this Laptop. It works with the BIOS attached. But when I flash this BIN to another Chip of the same type and solder it to the device, it won't come on. Power LED is blinking and webcam light turns on. Is it possible that the BIOS is connected to the Chip ID and is there any way to bypass? Thanks a lot!
  • hoaca388
    Badcaps
    • Jan 2022
    • 11722
    Add serial number to post.
      • 20848
      post the laptop serial number, and the part numbers of both bios chips.
      • REpairAT
        • Nov 2020
        • 142
        • Austria
        Serial is J1N0CX12E527036 and Chips are both W25Q64FWIG
        (My post above can be deleted, I forgot to quote in this one... thanks!)
        • hoaca388
          Badcaps
          • Jan 2022
          • 11722
          You should change to another chip, maybe the chip you choose is not good.
          • REpairAT
            • Nov 2020
            • 142
            • Austria
            The story is that I got around 10 of these tablets working, but with a BIOS password and one without, so I just wanted to flash the dump of the unlocked one to the others. Devices are all identical. I tried flashing the dump on two tablets already, they won't boot. And if I solder their chip to the one where the dump originally came from, the screen also stays black.
              • 20848
              You can`t just copy one bios from one and expect it to work on another. For one thing, you would have to clean the ME firmware (and copy the DMI,windows key etc). The bios you posted is the one without the password, post one that has a password. It`s an AMI bios, and if the password can be decrypted then the same password might have been used on all of them. If the password can`t be decrypted it can be patched with a hex editor easily to remove it.
              • BMCappelletti
                Asus Chromebox CN62 - wrong chip put on BIOS reader
                by BMCappelletti
                Long story short:
                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                - gave the computer to his son a couple years later
                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                (seems like the story was not that short)
                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                01-08-2025, 07:27 PM
                Common SPI bios chip programming Questions and Answers
                by SMDFlea
                Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                A: If you can`t read from it how do you expect to write to it ?.
                Q: Why is my bios chip unreadable ?.
                A: The programmer is faulty or has a worn or broken zif socket.
                The USB cable is frayed,connector pins worn or some other physical damage.
                Not enough amperage or voltage to power the programmer properly.
                Bad...
                09-02-2021, 04:40 PM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • JoWed
                Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                by JoWed
                Hello Community,
                I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                07-01-2025, 09:32 AM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
