DAG71MB16D0 REV: D EC Dump
This topic has been answered.
  • TecnicaNTT
    • Feb 2015
    • 69
    • Portugal
    I am in need of an EC dump for this motherboard: DAG71MB16D0 REV: D with a ITE IT8987E that got badly corroded. It is for an HP latptop model 15-CC504NP and with the following serial number: 5CD7244H6T​.
    The original got water damage and is badly corroded and missing pins so I can't read a dump from it to flash the new one.
    Attacched some pictures if it helps.
  • Answer selected by TecnicaNTT at 11-12-2024, 06:28 AM.
    SMDFlea
    • 20879
    Originally posted by TecnicaNTT
    Thank you!
    Here is the BIOS dump. If you succeed to extract de EC could you please indicate the area where it is located for future reference? Or what I should look for to identificate the EC area in a BIOS dump?
    Extracted EC. Search for the word ITE . First offset is at 200000 .
      • 20879
      Post your bios backup. We might be able to extract the EC from that.
      • TecnicaNTT
        • Feb 2015
        • 69
        • Portugal
        Thank you!
          • 20879
          Thank you!
          • TecnicaNTT
            • Feb 2015
            • 69
            • Portugal
            Thank you very much once again. I'll give a flash and comeback with news.
            • TecnicaNTT
              • Feb 2015
              • 69
              • Portugal
              Worked flawlessly! Thanks once again for the extraction and for the explanation so in the future I can look first in the BIOS for it.
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • Mephysis
                DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                by Mephysis
                Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                03-27-2025, 02:34 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                Today, 05:12 AM
              • hyperwood
                [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                by hyperwood
                I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                ✅ What I need:
                • A working 2MB BIOS dump
                • Matching NM-E471 Rev. 2.0, e.g. JY575
                06-25-2025, 02:28 PM
              • Andreas_de
                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                by Andreas_de
                Hello!
                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                04-12-2025, 10:38 AM
