svod4 error ic is not respondingi
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    i have a svod 4 programmer today when i am going to program bios then this error is coming can anyone tell me what is the problem in this programmer
  • Stefan Steff
    • Mar 2024
    • 412
    Set Power to 3.3V or 1.8V depending on your bios chip type.
    • Arshad alam4659
      • Aug 2020
      • 157
      • India
      I TRIED BOTH and i also firmware update
      • Stefan Steff
        • Mar 2024
        • 412
        Here why is not selected SPI 25 Flash or anything...
        Click image for larger version  Name:	image.png Views:	0 Size:	14.5 KB ID:	3500369
        This is how is looking mine when starting the program and selecting SPI 25 Flash:
        • Arshad alam4659
          • Aug 2020
          • 157
          • India
          yes you are right but that is the problem yesterday i connect the programmer then he auto connected but today he is not connecting to the system when i am manually set power 3.3v or 1.8v then showing mode of programmer and i am select spi25 and click read id then again showing select mode of programmer i want to know what is bootloader
          • Stefan Steff
            • Mar 2024
            • 412
            Then probably you have to press Setup->Update Firmware
            • Arshad alam4659
              • Aug 2020
              • 157
              • India
              THIS IS ALSO TRY
              I THINK THE CHIP WITH SOME PROGRAM INSIDE THIS PROGRAMMER AND ITS FILE HAS BECOME CORRUPT
              • Stefan Steff
                • Mar 2024
                • 412
                THIS IS ALSO TRY
                I'm out of other ideas...
                Try contact them on telegram group: t.me/SVODprojectTM,@SVODproject.
                Good Luck!​
                • izaak94
                  • Mar 2019
                  • 140
                  • mexico
                  Hi, do you know if svod4 supports 2Gbit chips?
                  ESMT F50L2G41XA
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    Replaced emmc.
                    Terminal log
                    UART
                    AC_ON
                    E-B
                    FDE enabled
                    06-01-2025, 02:11 AM
                  • sushilachuthan
                    APC UPS error P13
                    by sushilachuthan
                    one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                    the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                    The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                    We replaced the SCR with new device,, but the device is not power on as expected.
                    Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                    09-26-2025, 09:00 AM
                  • Superbee_dad
                    Sharp 80” long short flash backlight error - Help
                    by Superbee_dad
                    Hello Sharp TV experts
                    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                    01-24-2025, 11:51 PM
                  • STKR123
                    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                    by STKR123
                    Greetings badcaps community,
                    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                    I learned that desoldering...
                    10-29-2024, 06:03 AM
                  • 2elw
                    SVOD4 PCB pictures + parts
                    by 2elw
                    Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                    STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                    GW1N-UV9UG169C6/I5 FPGA - Its a...
                    07-04-2025, 12:23 PM
