svod4 error ic is not respondingi
  • Arshad alam4659
    • Aug 2020
    • 156
    • India
    i have a svod 4 programmer today when i am going to program bios then this error is coming can anyone tell me what is the problem in this programmer
  • Stefan Steff
    • Mar 2024
    • 249
    • Romania
    Set Power to 3.3V or 1.8V depending on your bios chip type.
    • Arshad alam4659
      • Aug 2020
      • 156
      • India
      I TRIED BOTH and i also firmware update
      • Stefan Steff
        • Mar 2024
        • 249
        • Romania
        Here why is not selected SPI 25 Flash or anything...
        Click image for larger version  Name:	image.png Views:	0 Size:	14.5 KB ID:	3500369
        This is how is looking mine when starting the program and selecting SPI 25 Flash:
        • Arshad alam4659
          • Aug 2020
          • 156
          • India
          yes you are right but that is the problem yesterday i connect the programmer then he auto connected but today he is not connecting to the system when i am manually set power 3.3v or 1.8v then showing mode of programmer and i am select spi25 and click read id then again showing select mode of programmer i want to know what is bootloader
          • Stefan Steff
            • Mar 2024
            • 249
            • Romania
            Then probably you have to press Setup->Update Firmware
            • Arshad alam4659
              • Aug 2020
              • 156
              • India
              THIS IS ALSO TRY
              I THINK THE CHIP WITH SOME PROGRAM INSIDE THIS PROGRAMMER AND ITS FILE HAS BECOME CORRUPT
              • Stefan Steff
                • Mar 2024
                • 249
                • Romania
                THIS IS ALSO TRY
                I'm out of other ideas...
                Try contact them on telegram group: t.me/SVODprojectTM,@SVODproject.
                Good Luck!​
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  The TV does not turn on, the standby indicator is on. All voltages are present.
                  Emms is dead. Not readable, not detected.
                  Replaced emmc.
                  But with another dump there is no launch
                  Terminal log
                  UART
                  AC_ON
                  RPMB key is not yet programmed
                  HASH1_VERSION=0x00000000 64bit
                  E-B
                  FDE enabled
                  layout pattern onebin by SAR7,0...
                  06-01-2025, 02:11 AM
                • Superbee_dad
                  Sharp 80” long short flash backlight error - Help
                  by Superbee_dad
                  Hello Sharp TV experts
                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                  01-24-2025, 11:51 PM
                • STKR123
                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                  by STKR123
                  Greetings badcaps community,
                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                  I learned that desoldering...
                  10-29-2024, 06:03 AM
                • 2elw
                  SVOD4 PCB pictures + parts
                  by 2elw
                  Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                  STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                  GW1N-UV9UG169C6/I5 FPGA - Its a...
                  07-04-2025, 12:23 PM
                • Maalobs
                  Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
                  by Maalobs
                  I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
                  The relevant service manual for the chassis is available here.
                  The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
                  When I short the SDM to ground I get the layer-2 error code 53.
                  The inside of the TV has no damaged components and no swollen capacitors.
                  In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
                  04-02-2019, 01:15 PM
