HELP: BIOS password foget problem for my AERO 15 wb laptop
  • Fei Dai
    • Nov 2024
    • 6
    • 美国
    Hi, bros. My problem as the title descriped, and I've tried to decrypt the cyphered password, but failed.
    The AMITSESetup block and my rom dumped are attached.
    The hex string: BBEF8533A42DACEB32C394CDB09205144F11D75AF54A374C392B4EB38A7F6A8A0000000000000000
  • shiyab
    • Sep 2023
    • 1348
    • india
    post dumb
    • qayyum786
      • Aug 2018
      • 1933
      • INDIA
      Try with:- iPiYMrc{U5f}
      • Fei Dai
        • Nov 2024
        • 6
        • 美国
        Originally posted by shiyab
        post dumb
        What are your meaning?
        • Fei Dai
          • Nov 2024
          • 6
          • 美国
          Thank you, but I tried it not right. I remember the password length maybe four
          • qayyum786
            • Aug 2018
            • 1933
            • INDIA
            Why don't you flash new bios and remove password
            • Fei Dai
              • Nov 2024
              • 6
              • 美国
              Thank you for your suggestion! However, I tried, and when the reflash goes to reboot, it still requires password😅
              Is there a way to avoid password ? I used the Aptio_V_AMI_Firmware_Update_Utility - AfuWin64 to flash.
              • volinakis
                • Jan 2021
                • 2725
                • N/A
                you need to use a programmer to get full backup of your bios chipset.
                • traxformania
                  TONGFANG "GM7TG7P" Bios Password Problem?
                  by traxformania
                  I tried :
                  -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                  11-15-2023, 07:32 AM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • AquaMan Ua
                  by AquaMan Ua
                  05-17-2025, 09:40 AM
                • outsider
                  Panasonic FZ-G1 MK5 - BIOS password returning
                  by outsider
                  Hello
                  I removed the BIOS password thanks to the help of one of the friends of this forum.
                  https://www.badcaps.net/forum/troubl...61#post3637661
                  The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                  06-17-2025, 12:51 AM
                • RMDUiFT
                  Should I buy a Lenovo Thinkpad E495 with bios password?
                  by RMDUiFT
                  Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                  I have a few questions:
                  • If I would buy this laptop and have
                  08-25-2024, 09:00 AM
