HELP: BIOS password foget problem for my AERO 15 wb laptop
  • Fei Dai
    • Nov 2024
    • 6
    • 美国
    Hi, bros. My problem as the title descriped, and I've tried to decrypt the cyphered password, but failed.
    The AMITSESetup block and my rom dumped are attached.
    The hex string: BBEF8533A42DACEB32C394CDB09205144F11D75AF54A374C392B4EB38A7F6A8A0000000000000000
  • shiyab
    • Sep 2023
    • 1697
    • india
    post dumb
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      Try with:- iPiYMrc{U5f}
      • Fei Dai
        • Nov 2024
        • 6
        • 美国
        Originally posted by shiyab
        post dumb
        What are your meaning?
        • Fei Dai
          • Nov 2024
          • 6
          • 美国
          Thank you, but I tried it not right. I remember the password length maybe four
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            Why don't you flash new bios and remove password
            • Fei Dai
              • Nov 2024
              • 6
              • 美国
              Thank you for your suggestion! However, I tried, and when the reflash goes to reboot, it still requires password😅
              Is there a way to avoid password ? I used the Aptio_V_AMI_Firmware_Update_Utility - AfuWin64 to flash.
              • volinakis
                • Jan 2021
                • 2877
                • N/A
                you need to use a programmer to get full backup of your bios chipset.
                • traxformania
                  TONGFANG "GM7TG7P" Bios Password Problem?
                  by traxformania
                  I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                  But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                  I'm trying to reset my bios without success.
                  I tried :
                  -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                  11-15-2023, 07:32 AM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • cr4zychriss
                  by cr4zychriss
                  • Rebrand: PC Specialist
                  11-14-2025, 04:04 PM
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
                • AquaMan Ua
                  Problem with PANASONIC CF53 laptop after changing BIOS settings
                  by AquaMan Ua
                  Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                  05-17-2025, 09:40 AM
