Lenovo P52 error P0284 Bios bug
  • Panzer Fahrer
    • Oct 2024
    • 5
    Hello!
    I received a Lenovo P52 20M9. When it starts it just makes a series of beeps. According to diagnostics, this is error 0284. I have already tested other bios with Ch341 but without success. Or the power LED lights up 3 times and nothing happens, or the beep sequence comes with 0284.
Name:	WhatsApp Bild 2024-10-25 um 08.26.50_b517dc28.jpg
    I hope that you can help me. It's too good for me to destroy.​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12269
    Originally posted by Panzer Fahrer
    Hello!
    Post original bios file and serial number .
    • Panzer Fahrer
      • Oct 2024
      • 5
      I have the original bios. but I think he didn't save it correctly. But it's worth a try.​
      Serial Number: PF190PVB
      • Panzer Fahrer
        • Oct 2024
        • 5
        I did some reading. Is there a way to repair a laptop like this if there is no bios dump.
        I have already tested various bios dumps from other users. There are 3 behaviors.
        Behavior 1:
        The "i" from ThinkPad and the power button flash 3x. Everything stays black and the device switches off.
        Behavior 2:
        Only beep melody which means Error 0284.
        Behavior 3:
        After starting, the keyboard lights up and the fans rotate for a short moment. Afterwards the device restarts, then the same behavior. Then there is a restart. Then comes Beep Melody (0284).
        I received the device with the 0284 problem, can this device still be repaired? or do the chances look very bad.
        Sorry about the bad English.​
        • McKey
          • Jun 2024
          • 53
          • Hungary
          power button flash 3x. Everything stays black and the device switches off​
          System are not detecting a bios chip. Check your connections in this case.
          • McKey
            • Jun 2024
            • 53
            • Hungary
            So... Yoga 370, same 0284 error.
            I saved the bios dump (attached), i checked it with uefi tool to get an idea of the cause, but i have no idea what to look for.
            SN:
            MP-184NWU 17/05
            TYPE:
            20JH-002TGE
            LABEL PN:
            SL10N17569
            • hoaca388
              Badcaps
              • Jan 2022
              • 12269
              SN:
              MP-184NWU 17/05
              TYPE:
              20JH-002TGE
              LABEL PN:
              SL10N17569
              This is thread of Lenovo P52.
              • McKey
                • Jun 2024
                • 53
                • Hungary
                Roger. I start a new one.
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • jendkkd jeje
                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                  by jendkkd jeje
                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                  10-11-2024, 03:12 PM
                • NecroFlex
                  Need fan error removed from BIOS Lenovo S200 10HQ
                  by NecroFlex
                  Hello, i have 2 of the same machines, the 1st one is dead, it is plagued by this issue (same board model):
                  https://www.badcaps.net/forum/troubl...=4#post1606399
                  So it's not worth saving (flashes lenovo logo for a sec, then reboots to a black screen), the 2nd one only has the fan error that stops it from booting unless you press F1. I'd need the error removed so that the system...
                  10-17-2024, 06:44 AM
                • 1g0r
                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                  by 1g0r
                  First, the data in brief:
                  Manufacturer: Lenovo
                  Model: ThinkPad L15 G3 21C3-0016GE
                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                  IC Bios 1: MX77L25650F
                  IC Bios 2​: MX25L25673G
                  EC Chip: NPCX997KAABX
                  So far I've been a silent reader, but now I need your help
                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                  01-18-2025, 02:39 AM
