HP 840 G7 Bios Password Removal
  • tigertec
    • Sep 2023
    • 16
    Please help,
    Build Id:
    BID=20WWCMBT601#SABA#DABA
    ​Featurebyte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcA,dUdpdqeMfPguhKhkjhk8mEmV.dD
    Serial: 5cg1043x42
  • shiyab
    • Sep 2023
    • 1506
    • india
    Originally posted by tigertec
    Please help,
    Build Id:
    Serial: 5cg1043x42
    flash 16 MB
    • tigertec
      • Sep 2023
      • 16
      That worked, but turns out that I have autopilot on as well. Can you help me?
      • tigertec
        • Sep 2023
        • 16
        Help?
        • qayyum786
          • Aug 2018
          • 1933
          • INDIA
          Help?
          Try
          • servis_null
            • Oct 2014
            • 82
            • Croatia
            Hello everyone
            I need help removing bios pass on HP 840 G7..
            HP EliteBook 840 G7
            ProdID 8PZ98AV
            SN# 5CG1354HLC
            Main and EC bios attached.
            Thank you
            • shiyab
              • Sep 2023
              • 1506
              • india
              Originally posted by servis_null
              Hello everyone
              HP EliteBook 840 G7
              ProdID 8PZ98AV
              SN# 5CG1354HLC
              Thank you
              hi try unlock
              • servis_null
                • Oct 2014
                • 82
                • Croatia
                Originally posted by shiyab
                hi try unlock
                Hi, this was fast
                Will try it later. Did DMI data get preserved? SN and stuff?
                • servis_null
                  • Oct 2014
                  • 82
                  • Croatia
                  hi try unlock
                  With your dump I got error "HP Endpoint Security Controller Problem"
                  • Stefan Steff
                    • Mar 2024
                    • 275
                    • Romania
                    Yes you got this error because didn't reset security options to default on very first boot.
                    Write this main bios now and enter this DMI data:
                    Description: HP EliteBook 840 G7 Notebook
                    Serial Number: 5CG1354HLC
                    Product Number: 8PZ98AV
                    Board CT Number: PJSCQ00WBFM4L1
                    BuildId(BID): 20WWCMDT601#SBED#DBED
                    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEnV.eT
                    MAC Address: E0-70-EA-38-5D-51​
                    • servis_null
                      • Oct 2014
                      • 82
                      • Croatia
                      Where should I add DMI data?
                      • Stefan Steff
                        • Mar 2024
                        • 275
                        • Romania
                        With HP DMI Tool NBDmiFit
                        Read here how to use it : https://www.badcaps.net/forum/troubl...ifit#post63219
                        ...or from Windows you can use this tool from HP : https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
                        I prefer this second method...watch here a tutorial : https://youtu.be/kQJuJZNOuXg?si=cfsrCtU8YT6KqrT4 and you can skip the partsurfer part because I give you all the information you need.
                        Good Luck !
                        • servis_null
                          • Oct 2014
                          • 82
                          • Croatia
                          Good Luck !
                          I tought there is some "special" way.. I am familiar with HP DMI fit tool..
                          Thank you very much
                          • servis_null
                            • Oct 2014
                            • 82
                            • Croatia
                            Good Luck !
                            I got same error after flashing your file.. After flash, first boot -> bios -> securtity tab -> reset to default -> save and exit.. and error still there.
                            • Stefan Steff
                              • Mar 2024
                              • 275
                              • Romania
                              OK, then we use bigger cannons )
                              Write this main bios and provide feedback.
                              • servis_null
                                • Oct 2014
                                • 82
                                • Croatia
                                It starts normal without error and asks for POST password.. like I flashed back original file.
                                • Stefan Steff
                                  • Mar 2024
                                  • 275
                                  • Romania
                                  Then the EC chip content is not patched...probably you wrote back the original...
                                  Use the shiyabs EC content from post #7 and the last main bios I provided and then there will be no password anymore.
                                  I made a lot of HP 840 G5 G6 G7 with this method and always had worked from first attempt (with or without Endpoint Security error...)
                                  • servis_null
                                    • Oct 2014
                                    • 82
                                    • Croatia
                                    OK, will try that later. Thnx for now.
                                    Funny thing that happened yesterday, I got main bios from a friend, flashed it and password was gone. But bios acted weird, I could enter bios, change setting, but when I wanted to add admin and POST password it would accept input but after restart it would not ask for that new password, it would just continue to Windows.. I didn't want to bother and I continue with Win install and stuff. After like 20-30 reboots.. it went back to lock state. wtf?
                                    • servis_null
                                      • Oct 2014
                                      • 82
                                      • Croatia
                                      Hey.. update..
                                      I did flash files as you mentioned and I got error again..
                                      Procedure I did:
                                      1. flashed both eeprom and solder them
                                      2. first boot - trying to enter bios - got error "Endpoint Security controller problem" - don't let me to bios (in bottom left corner says "Entering bios..") - notebook reboots..
                                      3. second boot - same as first
                                      4. third boot - shows error "Endpoint Security controller problem" but after pressing OK it lets me to bios, reset security to default and bios to default..
                                      5. after exiting bios shows error again but it boots to Windows
                                      6. later entered bios and disable everything regarding security: TPM, Secure boot, HP Sure secure, all related to security and now it doesn't show error "Endpoint Security controller problem" (don't know if this is smart)
                                      Regards
                                      • Stefan Steff
                                        • Mar 2024
                                        • 275
                                        • Romania
                                        Hey.. update..
                                        Procedure I did:
                                        Regards
                                        Disabling everything security related setting is not recommended...
                                        I made a new (last attempt) bios pack with EC and MAIN.
                                        Try to flash just the main maybe works because the EC is the same.
                                        At first boot enter to Security settings and reset to default. Very important!
                                        Then enter DMI data.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          Ack
                                          Ack
                                          01-30-2025, 04:26 AM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
