ASUS ROG R713RM Bios
  • rlohmann
    • Dec 2016
    • 6
    • germany
    Hi, could someone help to fix the bios?
    Laptop powers on (keyboard and power LED) and stay on.
    But no dispaly / start-sound and no USB access .
    PCB:
    G513R-MP-VGT
    6050A3348803-MB-A02
    2021-12-14
  • peste
    • Dec 2016
    • 13449
    • ROMANIA
    PCB:
    G513R-MP-VGT
    6050A3348803-MB-A02
    2021-12-14
    S/N ??
    • rlohmann
      • Dec 2016
      • 6
      • germany
      Hi, thanks for you support!
      Numbers from the backcover:
      G713RM
      SN: N4NRKD00009515D
      CN: A2S2
      • Markus1741
        • Sep 2020
        • 925
        • N/A
        G713RM
        SN: N4NRKD00009515D
        CN: A2S2
        Hello try this file good luck ....
        • Markus1741
          • Sep 2020
          • 925
          • N/A
          Hello, did the error occur after a BIOS update?
          There is also a very interesting video about this:
          https://www.youtube.com/watch?v=nwEQF07zB2Q
          Very interesting from 44:20.
          I don't know whether the original ASUS BIOS version 327 itself contains an error.
          Still, good luck.​
          • rlohmann
            • Dec 2016
            • 6
            • germany
            Thank you! Will check the video and give the bios a go.
            • rlohmann
              • Dec 2016
              • 6
              • germany
              Interesting video.
              Short update, the new bios does not work. Same (similar) behavior.
              Power / keyboard LEDs get on but notching else.
              Difference I noticed with the new bios, the CPU/GPU get warm but the fans does not start.
              Orig. bios, CPU get warm & fan start after a while , GPU appears to stay off.
              Btw, Laptop was working fine last time I used it. (approx. 4 weeks ago)
              Don't remember if Win applied a bios update last time I used it, but I don't think so.
              Will further check the mainboard ...
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • lrouw84
                by lrouw84
                Hi there,
                01-28-2023, 01:31 PM
