Request Bios for Asus Zephyru M15 (GU502LW)
  • Yongho Minale
    • Oct 2024
    Was repasting the laptop and replaced the fans. System booted normal and then froze. After manual shut down the power light and keyboard backlight turned on but not post of screen on (Fans turn on). Tried holding the power button, disconnected the battery, use F2, F10 and CTRL SHIFT B. dumped the bios using the C341a programmer. Looks like junk
    Model GU502LW-BI7N6
    SN: L9NRKD020400397
  • peste
    • 12835
    • ROMANIA
    Model GU502LW-BI7N6
    SN: L9NRKD020400397
    post the bios here on the site, not on other sites...post the motherboard model.
    • Yongho Minale
      • Oct 2024
      The main board is a GX502LXS
      Your site is not allowing me to upload the bios. said it's the wrong extension no matter what rename it.
      Update:
      Added the bios but would only allow it if it has the extension txt. Its really .bin
      • peste
        • 12835
        • ROMANIA
        Update:
        add the extension .bin and after loading in winrar or 7zip..
        • Yongho Minale
          • Oct 2024
          New file update for the bios
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • lrouw84
            Asus vivobook s510ua bios changed to x510un
            by lrouw84
            Hi there,
            I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
            I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
            01-28-2023, 01:31 PM
