Dell inspiron-24-7459 All-in-One ME clean request
  • poster1
    • Nov 2022
    • 20
    • Poland
    Please clean ME Region:
    IMPSL-PD rev a01
    I use Flash Image Tool 11 and 11.0.0.1178_CON_H_D_PRD_RGN.bin ME file, but outimage has still "initialized" ME status. (It should be "Configured", shouldnt it?)
  • danito
    • Jun 2016
    • 939
    • Romania
    IMPSL-PD rev a01
    try
    • poster1
      • Nov 2022
      • 20
      • Poland
      Thank You! Could You provide flash image tool you used to clean it?
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
      • diamon
        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
        by diamon
        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
        Pictures of these boards:
        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
        Dell...
        02-28-2024, 12:51 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • OntarioTL
        Dell 5410 greyed out BT
        by OntarioTL
        Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
        If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
        Dell Lattitude 5410
        Service Tag...
        07-25-2025, 01:28 PM
