Getac V110 G5 Bios dump needed
I don´t have proper Backup. If you want I can post disfunct backup as well, but I don´t see the point.Attached FilesLeave a comment:
try. you have to transfer DMI since you didn't provide your bios backupAttached FilesLeave a comment:
I guess rules are rules.
RL503V2716Leave a comment:
Hi!
I am in desperate need for a Bios dump from an Getac V110 G5.
It needs to be from a stock V110 G5, not a Bosch DCU220 (that also is labeld V110 on the bottom).
If it is password locked, that is no problem.
Thank you in advance!
Tags: None
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
Channel: BIOS Requests ONLY!
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
I badly need bios dump for HP DM1-4000er,
Model: HP DM1-4000er
Motherboard: DA0NM9MB6D0 REV.D
Product: QJ490EA#ACB
Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
- Loading...
