Getac V110 G5 Bios dump needed
  • GrafZahl
    • Jul 2013
    • 29
    Hi!
    I am in desperate need for a Bios dump from an Getac V110 G5.
    It needs to be from a stock V110 G5, not a Bosch DCU220 (that also is labeld V110 on the bottom).
    If it is password locked, that is no problem.
    Thank you in advance!
    • 21389
    Post the S/N https://www.badcaps.net/forum/troubl...before-posting
    • GrafZahl
      • Jul 2013
      • 29
      Originally posted by SMDFlea
      I guess rules are rules.
      RL503V2716
        • 21389
        RL503V2716
        If you have a backup post it, even if its the Bosch version.
        • volinakis
          • Jan 2021
          • 2789
          • N/A
          RL503V2716
          try. you have to transfer DMI since you didn't provide your bios backup
          • GrafZahl
            • Jul 2013
            • 29
            Thank you very much. Do you have by any chance a dump of the EC as well?
            The file does not work for me as is yet, but EC is shown as corrupted, so maybe it is that.
            • volinakis
              • Jan 2021
              • 2789
              • N/A
              post your backups, as in RULES. You can find bios and EC on web page of Getac.
              • GrafZahl
                • Jul 2013
                • 29
                I don´t have proper Backup. If you want I can post disfunct backup as well, but I don´t see the point.
                • volinakis
                  • Jan 2021
                  • 2789
                  • N/A
                  "the point" is that having even broken backup I can see what ME firmware I have to use in order to build bios image, version of bios and DMI, also if ME_Region is faulty and so on.
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • TacticalFahrrad
                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                    by TacticalFahrrad
                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                    06-30-2025, 04:09 AM
                  • vinaypundith
                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                    by vinaypundith
                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                    08-03-2024, 12:32 PM
                  • James Maxwell
                    HP DM1-4000er Bios Dump needed
                    by James Maxwell
                    I badly need bios dump for HP DM1-4000er,
                    Model: HP DM1-4000er
                    Motherboard: DA0NM9MB6D0 REV.D
                    Product: QJ490EA#ACB
                    Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                    10-28-2024, 05:38 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
