hp victus 16-e0511na(4h2y5ea) dump fil repair
  • layad
    • Nov 2011
    • 249
    hi there ,
    this laptop has no display need help repairing the bios dump file pls
    sr: 5cd151nm9y
    motherboard model: g3m
    thanks
    • 22427
    Originally posted by layad
    hi there ,
    sr: 5cd151nm9y
    thanks
    Here`s a virgin bios plus the DMI offsets,so you can add your DMI from your backup. https://www.badcaps.net/forum/troubl...74#post1831374
    Use the Guides to find and extract a virgin bios
    [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
    [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
    Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
    Offsets:
    DMI: 303000 - 303FFF
    Windows key: 325000 -32503F​
    HxD Hex editor https://mh-nexus.de/en/hxd/
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
