Unfortunetelly, without change. All right voltages are present, charging, fans are spinning, warming CPU and GPU, no shortcut on board.....still no picture even on external or internal display.
HP Victus 15-fb******
Hello all, I have this HP Victus 15-fb1000ca and I am suspecting bios is corrupted, as soon as the laptop powers on the power button blinks once (white light) and nothing after. Black screen. Everything seems normal on the motherboard. I have attached the bios bin read file. I have the bios dump from HP's website, i was hoping someone could explain where or how to modify the clean dump to match my serial number etc.
As per posting rules:
Model: HP Victus 15-fb10000ca
Serial Number: 5CD34293F9
Prod ID 8G9JOUA#ABL
Motherboard Model Number: DAG3PRMB8D0 REV: D
Any help is appreciated. Thanks!Attached FilesComment
Search your S/N with hex editor, you'll find a block containing all that info, copy that block to new BIOSi was hoping someone could explain where or how to modify the clean dump to match my serial number etc.
For Win key, search in hex 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00, copy that too
Try, BIOS extracted from HP website with serial/Win key inserted
Victus Gaming Laptop 15-fb1000ca (8G9J0UA)
BID 08C30
BIOS ver F.08
S/N 5CD34293F9
DMI+Win key 58000-5A03FAttached FilesComment
Hello, I'm French and I'm trying to find the BIOS for an HP 15-fb0200nf motherboard DAG3PPMB8D0 REV D MODEL:G3PP because there's no display. I'm posting the current BIOS. I hope you can help me. I tried the ones on this page, but it didn't change anything: https://www.badcaps.net/forum/troubl...model-g3p-bios
Forgive my language, I'm using a translator. Thank you.Attached FilesComment
post S/N, full name and model, motherboard model, product number,etc.Hello, I'm French and I'm trying to find the BIOS for an HP 15-fb0200nf motherboard DAG3PPMB8D0 REV D MODEL:G3PP because there's no display. I'm posting the current BIOS. I hope you can help me. I tried the ones on this page, but it didn't change anything: https://www.badcaps.net/forum/troubl...model-g3p-bios
Forgive my language, I'm using a translator. Thank you.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Thanks for the reply. I tried flashing this BIOS image, and still same error. Power button blinks white once. Does not do anything, black screen. Charger plugged in shows red light and charging fine. Any idea what next to check?Search your S/N with hex editor, you'll find a block containing all that info, copy that block to new BIOS
BID 08C30
BIOS ver F.08
S/N 5CD34293F9
DMI+Win key 58000-5A03FComment
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
The page you linked is for the Intel 12th gen version, yours is AMD Ryzen 5 5600HHello, I'm French and I'm trying to find the BIOS for an HP 15-fb0200nf motherboard DAG3PPMB8D0 REV D MODEL:G3PP because there's no display. I'm posting the current BIOS. I hope you can help me. I tried the ones on this page, but it didn't change anything: https://www.badcaps.net/forum/troubl...model-g3p-bios
BIOS backup is incomplete, you only read the first 1MB, it should be 16MB, check your programmer settings, manually select W25Q128JW or equivalent chip, luckily the serial/win key is there
BIOS extracted from HP website with serial/win key inserted
Victus Gaming Laptop 15-fb0200nf (7C2M0EA)
BID 08A3C
BiOS ver. F.21
S/N 5CD242H142
DMI+Win key 26000-2803FAttached FilesLast edited by m1ch43lzm; 09-03-2025, 05:24 PM.Comment
Check for hardware problem, maybe you have a short somewhere on a secondary power rail, please start a new thread in Troubleshooting Laptops, Tablets, and Mobile Devices sectionComment
Unfortunately, I only saved that. Since then I tried injecting several BIOSes that I found on your forum but the screen remains black. I also tried injecting the 08A3C.bin from the HP site. It doesn't change anything.The page you linked is for the Intel 12th gen version, yours is AMD Ryzen 5 5600H
BID 08A3C
BiOS ver. F.21
S/N 5CD242H142
DMI+Win key 26000-2803FComment
I didn't see that you had prepared a Bios for me. Thank you very much! However, the screen remains black. There may be another problem...Comment
Hello everyone, I hope you can help me repair my file. It only shows a black screen. I am attaching all the machine data, and I would greatly appreciate your help
HP 15-FB1013DX
PRODUC ID 845A2UA#ABA
SN: 5CD338C6RL
MOTHERBOARD : DAG3PRMB8D0REV D
Try reading the BIOS chip again, your BIOS backup is almost empty, most of it is 00 00 or FF FF, cannot get the serial/model/product ID/etc. from your BIOS
If that fails, try post 5 https://www.badcaps.net/forum/troubl...64#post3344564
Or post # 43 above
Try on a new BIOS chip if possible W25Q128JW, W25R128JW or similar 1.8V chip
Edit serial/product number/etc. with HP BCU if it works
https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
Code:Serial Number : 5CD338C6RL SKU Number : 845A2UA#ABA Product Name: Victus by HP Gaming Laptop 15-fb1xxx Build ID: 23WW2OHZ601#SABA#DABA Feature Byte: 3K5F6b7KaBapaqasawbhcbfPfdkFm9mzncpnpqprqt.y4 System Board CT Number: (check a sticker on the motherboard)
After performing a BIOS update on my HP Victus laptop, I noticed that some system information (like S/N and product number) was either missing or altered. I suspect the BIOS is corrupted.
Since then, I’ve been experiencing serious stability issues:- The screen freezes and crashes after a few minutes of use.
- By uninstalling the GPU driver, the system runs with 16GB of RAM, but graphics performance is unstable.
- By updating the GPU driver, the system consistently freezes and crashes, and after reboot, only 8GB of RAM is detected instead of 16GB.
The process completed without errors but after rebooting, same issue, nothing has changed, and data is still missing in BIOS.
I need help to rewrite or restore the system information in the BIOS.
Thanks in advance!
Victus by HP Gaming Laptop 15-fb0160nf
S/N = 5CD248B6FR
MOTHERBOARD = DAF3PMB58B0 Rev.B (G3PQ)
AMD Ryzen 5 5600H 16Go 3300 MHz (CPU) Radeon RX 6500M (GPU)
BIOS = AMI F.24 Rev.A, 04/09/2025Attached FilesComment
Description : Victus by HP Gaming LaptopHello everyone,
Thanks in advance!
S/N = 5CD248B6FR
Serial Number : 5CD248B6FR
Product Number : 6R480EA
Buil ID : 22WW3OHZ601#SABF#DABF
Fearture byte : 3K6b7K7zaBapaqasawbhcbdXfPfdkFm9mzncpnpqprqjqt.he↵
https://www.badcaps.net/donateComment
Most likely RAM fault, remove both RAM sticks, clean the contacts on the RAM, try with only 1 RAM stickHello everyone,
You attached clean BIOS from HP, not the contents of your BIOS chipI need help to rewrite or restore the system information in the BIOS.
Thanks in advance!
S/N = 5CD248B6FR
You should also see "Manufacture Programming Mode is in Unlock mode" text on a blue rectangle at power on, else BCU won't work
Like this:
Use BCU to enter the following, only if you have the Manufacture mode... message at boot
Yes, Product name should be written as "Victus by HP Gaming Laptop 15-fb0xxx"Code:Product name: Victus by HP Gaming Laptop 15-fb0xxx Serial Number: 5CD248B6FR Build ID: 22WW3OHZ601#SABF#DABF SKU number: 6R480EA#ABF Feature Byte: 3K6b7K7zaBapaqasawbhcbdXfPfdkFm9mzncpnpqprqjqt.he System Board CT Number: (it's on a sticker on the motherboard) System Family: HP VICTUS
If you don't have the Manufacture Programming Mode message, you need to use a programmer to flash BIOS extracted from HP website, the BIOS chip is 1.8V, you need a programmer that supports 1.8V SPI Flash chips, make a backup of the current contents of the BIOS chip first before flashing another BIOS
The RAM is ok, I cleaned and tested both on slot 1 and 2 respectively, plus I did a MemTest86 once the system detected 16GO, and all the results are good.Originally posted by m1ch43lzm
I don't have a programmer, so I tried to make a copy of my BIOS using AMI Firmware Utility and then Flashrom booting from Linux, but both process failed each time with error messages... I don't know which method to use to get it.Originally posted by m1ch43lzm
However I was able to put my hand on an original BIOS with same ref as my laptop though... Is there any way it can help ?
Code:System Board CT Number: RMMCD7FM1HF9LV
Don't know of any software method of flashing a modified BIOS, or overwriting the full BIOS image on HP laptops (especially with AMD CPU), as usually the area where the S/N and Win key is located is not overwritten during a normal BIOS update, the regular update procedure skips that section
You can try creating the BIOS recovery USB drive from sp158225.exe and follow the instructions there:
https://support.hp.com/us-en/documen...413-2337994-16
But since that's an "official" method, it also doesn't change the MPM Lock which you need to enter serial/product name/SKU/feature byte, etc. with HP BCU
The BIOS can't be downgraded either via software
Only way that I know of is using a hardware programmer- Provides the 2025.1 security enhancement. NOTE: After this BIOS update is installed, previous BIOS versions cannot be reinstalled.Comment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by Yacine007hello dear friends
I recently bought this motherboard and I'm having a lot of problems.
- The Wi-Fi doesn't appear in the Network Card in Device Manager (The Wi-Fi card and the Wi-Fi work fine when I installed the old motherboard)
- The hard drive is missing when i reboot the system and reappears when i reboot again (crtl+alt+del).
- When I tried to do an internal BIOS update it doesn't work it always fails.
Can someone help me update the BIOS or give me a new clean BIOS?
hp Victus 16-e0xxx
SN 5CD2050PSQ
Thank you in advance...-
- Loading...
